Installed my Fogs finally.
Custom mounted on my 03 where the road lamps go. PIAA 001 Yellow fogs. Got yellow cause I couldn't get a good match with the stock HID's. These seem to be good. Since it's been raining like crazy they do work good, & I can see better. I'm using the TL factory fog light switch, I still need to finish that part though. Should be up today. Here are some pics.
Off
http://community.webshots.com/photo/...89451608UOkKTT
On
http://community.webshots.com/photo/...89451735xbFvbC
Wiring is basic. Power, ground, & turn on. Had the relay all wired already I just ran the wires where they needed to go. Ran turn on to the drivers side marker light. This way the lights only go on when the cars lights are on, & I can turn them off if I want. The lights are mounted into the black housings using stainless hardware painted black. The lights are a good fit, but they were troublesome. The drawback is when I need to change bulbs, I have to un-mount everything. Not hard but a PITA.
Off
On
Blown LS6!!
Re: Installed my Fogs finally.
Seattle Cl-S
Didn't think of that. I was going to turn them off each time anyway.
SportShiftTypeS
No Comptech badge, don't think it was me.
Silverbulit40
DIY instructions? Didn't really make any.
All I did was unmount the 6 speed black housings(held on by a screw you can access by taking the front cover off by the hood latch)
Drill a 1/4 hole in each housing for the wires.
Drill 2 holes in each housing to line up with the PIAA light mounts.
Used 2 small nut/bolts, to bolt down the PIAA fogs to the housings
Ran the PIAA wire harness to each light(tie wrapped, & wire molded everything)
Installed the housings back into the car
Mounted the PIAA reley on the drivers side fender
Ran + to battery
Ran - to battery
Ran turn on to drivers side marker light
Ran the switch wire through the firewall
The TL switch isn't in yet. I'm tring to wire it now. I had to make a wire harness cause the switch has 5 pins, but the PIAA kit only has 3 wires. Should be in by the weekend.
SportShiftTypeS
Silverbulit40
Ran + to battery
Ran - to battery
1 Post
i have fogs installed, but found a circuit that only allows me to turn them on only when high beams are OFF (inspection issues) and headlights are ON. I haven't bene able to figure out how to wire them so they turn on with just the corner lights yet.
That's the "legal" way to wire them. They should turn off when the high beams come on. I have no inspection so I wired them different. Hard to believe they really check something like that. You might be able to split the turn on wire & run it to the marker light also.
Installed the TL fog light switch, looks great, & looks stock. Lights up when I have my headlights on, & turns green when the fog lights are turned on, just like stock. The only thing it doesn't do is dimm with the dimmer, but I don't use that anyway. If anyone wants the switch pinouts PM me. Here's a pic, I know it's blurry, My camara doesn't take good pics anymore.
http://community.webshots.com/photo/...90150978ZizKam
Blown LS6!!
It's not over yet
InFaMouSLink
10-27-2015 06:51 PM
09-17-2015 09:01 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
