Injector question
Injector question
I'm wanting to replace my injectors.
Also want one step beter than whats in my engine now,and for the cheapest I can get them for.
They don't have to be big raced out injectors since my motor is not raced out.
What one's are a good drop in upgrade from stock.
9.5 lbs o' Boost!!!!
your not going to need bigger injectors than stock if your not going to be running a ton of power. I was running stock injectors with and was running 350 WHP in my CLS. If you want a upgrade get some deatchwork 220 injectors. you will be happy with them.
wham bam thank you ma'am
for what ur doing u dont need bigger injectors, as of now. but when u spray 150-175 plus all the na bolt ons. get some s2k injectors (370-390cc) or some rdx injectors (410cc). i made a diy on how to fit them into the tl/cl. runners. also upgrade the fuel pump and a fpr is recomended.
but u dont want to spray on teh track and find out the hard way that u didnt have enough fuel. thats how the rumors about nitrous blowing up engines is made. no tune, no fuel, boom. blame it on the nitrous. but u should be blaming it on the driver/owner.
get a tune before u spray
B A N N E D
why not take your injectors out and get them flowed and balanced? (IE they will clean tem and make them all flow the same amt of fuel.
you'll have to google it but this site goes over the basics
http://injectorcleaning.com/html/contact.html
this site lists an average price of $26.25 per injector and a 1 day turn around
http://www.rceng.com/Fuel-Injector-Cleaning-P43C0.aspx
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
