Ingalls engine dampner test vehicle?
#41
Originally Posted by Louie11
This has already been done by a shop called Garage Kwai. They made one for 02av6. He purchased an off brand dampner on ebay(probably the one you found) and they made him a bracket for $100. They mounted it from the shock tower to the block. I go to this shop for my performance needs also. The reason for me even starting this thread is that I like how ingalls gos to the engine mount instead of on the block. I'm probably just paranoid, but i just think this is safer. If ingalls does not want to pursue our application then I will be going to Garage Kwai to have them make me one.
#44
That's Racist
Originally Posted by jproy
only for a hour or so. maybe twice. I will find out exactly. where are you located? you can call the number above for NRG Innovations.
#46
MP90 uninstalled
I started another thread called "engine damper interest thread". please post your interest there so I can see how we could work a group buy. NRG Innovations is working on this.
#47
That's Racist
#49
Originally Posted by CleanCL
i don't understand. it needs to bolt to the engine or it is pointless.
#50
MP90 uninstalled
so louie11, there are four engine mounts to the chassis. what do you mean when you say mount the damper at the engine mount. first off what engine mount are you talking about and if you are talking about a particular mount how do you plan on mounting it there? the best and simplest way to do it seems to be from the top shock tower to the bolt that holds the power steering pump to the block. if 02Av6's supercharged motor doesnt impose any problems mounted from the shock tower to the steering pump so why do you think it could cause a problem on a weaker motor in our car. weaker by not supercharged.
#51
That's Racist
I just called Roth over @ NRG innovations; he asked me to shoot him an email and provide him my information. He will then go through w/ the marketing department to see what can be done for the CL.
I'll send him my email right away and keep y'all posted.
#53
#54
MP90 uninstalled
the motors in the ingalls instruction are all 4 bangers. they are also mounting it to what appears to be a bracket on the power steering and the block, both. it is the same structuraly, i'd say. there were only three bad pics, so Im not sure, but pretty sure.
rockyboy
08-04-2024 10:35 AM
rockyboy
01-25-2016 06:00 PM
