IM F'D! need help from everyone
#122
Originally Posted by Zippee
Maybe I missed something, but why are you pissed at the dealer? It is Mastertech that is refusing the claim, not the dealer.
sidemarker
#123
Originally Posted by JaredGMS
What do you mean?
well i was trying to find a lawyer online but there are so many of them i dont even know where to start...
sidemarker
#124
Man good luck dude.
But honestly, this will be tough. THe dealer will not want to take their workers to fix this car. What sucks more, the warrenty company will see that 7k total to fix and fight very hard, especially if you didn't have that much time left on the warrenty. Your mods won't help at all.
It really sucks but wish someone u knew could have helped you at the dealer. The dealer would 1st diagnose the problem, tell the warrenty company the part is fucked, it needs replacing. The warrenty company would send someone out to check it out and approve.
Since the aftermarket parts came up, man they fucked you. Or you should have re-installed the OEM intake.
Most warrenty companies are 3rd party. They usually offer 3 diff levels, silver, gold, platinum.Since Acura is a reliable company usually, for the warrenty company this is a great sale. They figure much won't go wrong, no work for them or check writing to you.
Sorry to hear this dude. You may need some sort of documentation from an outside mechanic or 2 stating a CAI cannot affect what broke.
#125
Meat stick
sidemarker
sidemarker
Good luck!
#127
just as i figured
called the extended warranty company up. DENIED!!!
i just finished a meeting with the dealerships general manager. I dont know if its part of his job or if he is really telling the truth but he thinks he should be able to fix the situation...
so who knows, maybe today maybe monday ill know for sure where im at
sidemarker
sidemarker
#128
Meat stick
just as i figured
sidemarker
sidemarker
GO GET 'EM!!!
#130
Sold but not Forgotten...
Sidemarker wish ya all the best to solve this issue... after what the warranty company is doing man I would be pissed... Will check and make sure I got the acura warranty...
man I really wish u get it covered....
#133
@ slide or die @
Sidemarker, just a piece of advice:
*I didnt read pages 3-5. but:
TO ALL THOSE WITH MODS: when this kind of serious stuf happens, its wise to take or hide your aftermarkets since now, warranty companies look for this first and FUK YU IN DE AS!! I was recently denied a new inverter for the headlight because the ground wire for the headlights "had been moved at one time" when i installed my cai. ('99TL) = $22x.xx w/ labor!!
my friend's eclipse blew his motor (drag racing) and he called me and some friends up at 2am on a school night to help him turn his car as stock as possible overnight, and we're talking about a car with $2000 in performance mods...we were done by 1pm that day after no sleep and 4ppl working in the side of the street at night with flashlights and all morning with retards in cars looking at us like freaks.
Anyhow, he got most of the damages covered.
i'll post pics later when our friend here finishes this madness. Good luck. keep us updated.
#134
@ slide or die @
#135
@ slide or die @
HEY READ, i got some important imformation:
Originally Posted by online
YOUR RIGHTS:
Point out to the dealer the provision of the Magnuson-Moss Act- Require that he explain to you how the aftermarket equipment caused the problem. If he can’t – or his explanation sounds questionable – it is your legal right to demand he comply with the warranty.
Fact: If you are still being unfairly denied warranty coverage, there is recourse. The Federal Trade Commission, which administers the Magnuson-Moss Act, monitors compliance with warranty issues. Direct complaints to the FTC at (202) 326-3128.
#136
#137
someone please look at this agruement and let me know if it will stand or fall
modifications and alterations to the powertrain would be the install of a supercharger. Since the supercharger uses a rotary device which is custom fabricated into the engine bay it creates substantial power by forcing more air into the engine. Force induction is a method which is NOT the original way for the current motor to function therefore it would be considered modification/alteration to the powertrain because it has changed the way it performs. However a aftermarket equpiment that is a direct bolt on like a air intake does not in fact change the way the powertrain operates. It uses the same connections as the OEM part and the functions are the same as the OEM part.
i could talk about turbochargers too...
any suggestions...
sidemarker
any suggestions...
sidemarker
#138
i could talk about how changing the timing is a modification or changing the the ecu is another way too...
or the introduction of NOS into the motor is a modification because the presence of another element that was not original way of operating...
sidemarker
sidemarker
#139
modifications and alterations to the powertrain would be the installation of a supercharger. Since the supercharger uses a rotary device which is a custom fabrication for the engine bay, it creates a substantial power increase by forcing more air into the engine. Force induction is a method which is NOT the original method of operation for the current motor and therefore it would be considered a modification/alteration to the powertrain by changing the way it performs. However an aftermarket piece of equpiment that is directly bolted on, such as an air intake, does not in fact change the way the powertrain operates. It uses the same connections as the OEM part and the functions are the same as the OEM part.
#140
sidemarker
#141
thanks for embellishing it, just wanted to get the point across. so do yall think this makes sense or should i go a different route...
sidemarker
sidemarker
I wouldn't play word games with them. Try to make the point that the modification that you did was not the cause of the failure.
#142
Something can be a modification even if it bolts right in. In the case of an intake it is a modification as it changes the amount of air flow to the engine.
I have an aftermarket part that bolts on and uses the same outlet and all necessary tubings. it uses the basic materials to provide the engine what it needs to operate originally. There is no evidence only assumptions that it "could" change the airflow of the box. How do we not know if the OEM airbox is in fact a better air flow system? If we look at other vehicles YES there is postive gain in horsepower for the majority of the cars, but the outcome varies from cars to cars. And does airflow really matter? IF they put my car on a dyno and they measure the amount of horsepower gain or loss how would that benefit them? Eventhough most of the people on the board drive a cl-s everyones power output is different. some are almost the same and some are just very different. They would need to test two cl-s for this specific test and i doubt they will go to these measures to do so. Even if they did tell me what could they accomplish from this case???
sidemarker
#143
the reason why i have to play this word game is because they are playing the word game with me
I CAN NOT USE THE WORD MODIFY they keep insisting that i modified the car so i have to keep claiming i did not!
sidemarker
sidemarker
#144
ok lets pretend they say "well it is a known fact that an aftermarket intake will produce more horsepower and thus cause more strain on the engine which could cause your motor to fail."
i wish they would say that so i can say PROVE IT!
then i would be on my way to "check mate"
sidemarker
sidemarker
#145
Meat stick
sidemarker
sidemarker
Good luck.
#146
I know this is crappy advice, but I say to wait for the Acura guy to get back to you on Monday, and see what happens with that. I think you, by yourself, are in a stalemate with the ins. company, and if the Acura guy cannot help, it's lawyer time.
Good luck.
Good luck.
i understand that, but i dont want to waste any time so if acura is no help i want to make sure im prepared to fight this out some how...
sidemarker
#147
sidemarker
sidemarker
Only shot you have is to prove that the modification was not the cause of the engine failure.
#148
The truth is you modified the car by changing the intake. To say it makes less power or the same as stock is bullshit. We both know the reason you bought the aftermarket intake was to make more power.
My point is this, they are using the word "modification" unfairly. Like my example before if i changed out the air filter to the OEM airbox or maybe even replace the sparkplugs would that be considered a modification? The contract also notes that if it is approved by the manufacture it is considered legit. but i dont see a list anywhere from acura/honda that tells me that a generic muffler or denso spark plug, or K&N filter is approved or not approved. The contract states that I DONT HAVE TO SERVICE my vehicle at the dealership so if i take it to another shop and they put in all those replacements would that be considered legitament to acura/honda standards?
furthermore the warranty company lacks the proper definition of powertrain. It is so broad that even the battery could be considered part of the powertrain.
let me take another angle now. for example if i had aftermarket sound system in my car running an amp kit to the battery, I have to THEIR DEFINITION altered the powertrain so my warranty would be void.
i understand what you mean as far as having them prove that my so called aftermarket parts caused the problem, but the issue is that the warranty company does not want to make any other statement besides:
"you have modified the powertrain therefore your coverage is denied."
so i have to take the angle of NO I DONT HAVE MODIFICATIONS! I have aftermarket replacement equipment parts.
sidemarker
#149
they have made it clear to me that they only want to use the word "modification." However does an aftermarket replacement equipment qualify as a modification?
I hope the dealer can help you out, but if the warranty company wants to deny coverage I think they have you by the balls.
#150
Beware of leakage
^^ but there is no modifying of anything (except lowering the car via Springs), purely replacement. Even if he was to replace the spark plug, it would be one specified for the car, not just going to the auto parts store blindfolded and going "ok these feel like the ones".
Replacement
Replacement
#151
zippee
you are obivously missing the point i am trying to make, i am not intiating this so called "word game" the warranty company has made a statement and it is clear that they dont want to elaborate the denial for coverage. I am simply trying to use what they have said against me to better my case. They said i modified the powertrain, but who are they to determine what is considered a modification? Would you suggest that a modifciation and aftermarket replacement equipment are synonmous?
if i spray NOS or added a comptech SC then yes i believe im dead in the water with no way out and of course i would not be in this mess. You play you pay!
also, hypothetically if i didnt have the i/h/e, instead had an aftermarket sound system with an amp kit installed to the battery and i had the same engine problem that i have right now i am 99.9% sure they would void my warranty BECAUSE I HAVE MODIFIED THE POWERTRAIN OF THE VEHCILE!
that is the only thing im trying to point out here, they are not being fair at all. I paid for this policy so that IF i need repairs THIS INSURANCE company would cover the problem. THEY are not doing their job and I am pissed off at them!!!
sidemarker
sidemarker
#152
its any easy resolution
i authorize the work on the car, dealership tears down the motor, inspector comes in to determine the problem, he/she will conclude it was either A) mechanical failure or B) found evidence of outside influence caused from an aftermarket part.
but nope they just want to play this game of, we see your cars been modified so there is no reason for us to further investigate the problem of your car!
the magnusm-moss warranty act should kick in but i think i need a lawyer for that
so in the mean time i will use as much resource as possible (acura) to help me with this situation before i go get me a damn lawyer...
sidemarker
sidemarker
#153
While taking off the factory airbox and installing something else is a "replacement", it is also a "modification".
#154
My understanding from one of the earlier threads was that he had installed a cold air intake and that is the mod that is being used to deny the claim.
you see just like what allmotor said
suppose my exhaust manifold was damaged because i hit a rock. I got it replaced with comptech exhaust manifold because they were cheaper then the OEM manifold. So my warranty is still void. that is a bunch of crap!
sidemarker
#155
you see now im starting to understand why some people are denied warranty coverage if they put a sound system in their car. anything linking it to the powertrain and you will be screwed!
so watch out those with aftermarket alarm systems you could lose your warranty now!
sidemarker
sidemarker
#156
zippee
I hope you get some help from the dealer but I think that you better start looking for a lawyer.
#157
since when did an aftermarket part have to be identical to OEM parts?
there is no language in the contract specifing that the parts have to be idientical or equal to OEM parts
for example a oil filter, would you consider them all identical? i dont. they all have similarties and function the same way but the size are different and the filter inside are different as well.
I believe i have satisfied my part of the contract...
#158
well zippee it is obivious you dont feel my point is strong enough, if i may ask, do you think i have any other way to dispute this case before going to a lawyer?
sidemarker
sidemarker
#159
Getting the wrong one can jump up and bite you in the ass. Just because it screws on doesn't mean it will work properly. For example there is a larger filter that some folks are using. I have read in one of the threads here that the internal construction is different and it doesn't do as good a job of getting the crap out of the oil. I figure that Honda knows what they are doing and use only OEM oil filters.
If you show up at the dealer with chewed up bearings and one of these filters on you may well not be covered.
#160
sidemarker
sidemarker
A while back you posted that the mechanic who tore the engine down didn't think your mods were the cause of the problem. He is the one you need to get to talk to the insurance company and if you the legal route, have your lawyer get a deposition from him.
Good luck!
