IDRC question...
IDRC question...
What would happen if you manually open the IDRC and leave it that way? With the connector still on there, can you leave that valve open all the time? Or does it have to open at 4100rpm and above only? Any thoughts?
disconnect it and it stays closed.
All boosted members should disconnect it.. it cause too much air turbulance and the S/C'ed vehicle will detonate in the higher RPM's.
so cal type s_RENAMED
02-10-2001 07:41 PM
