I just won this Ebay bid!
Happy CL-S Pilot
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2481652402
It's the Carchip E/X.
I will report once tested!
2004 Euro Cup Champions
data logger are awesome. How many values a second does it log?
Do you have excel? i'd love to see some spread sheets on what you log.
Do you know how to use it? i could give you some tips if you like. i use one for obd I systems for my rally car. I'm pretty sure there are only some differences, like the o2 sensors reading in % rather than volts.
Happy CL-S Pilot
Yep, I got in the mail today. I do appreciate if you can help me use well. I do have excel and I can export to excel too!. I did a small 10 min trips around the block. If you are interested I can email the .xls file.
I can log any 4 of the following values:
List Of Data Parameters
The following vehicle data parameters can be logged by the CarChip data logger:
Vehicle Speed
Engine Speed
Throttle Position
Coolant Temperature
Engine Load
Intake Manifold Pressure
Air Flow Rate
Intake Air Temperature
Timing Advance
Fuel Pressure
Fuel System Status
Short Term Fuel Trim (B1)
Short Term Fuel Trim (B2)
Long Term Fuel Trim (B1)
Long Term Fuel Trim (B2)
O2 Sensor Voltage (B1, S1)
O2 Sensor Voltage (B1, S2)
O2 Sensor Voltage (B1, S3)
O2 Sensor Voltage (B1, S4)
O2 Sensor Voltage (B2, S1)
O2 Sensor Voltage (B2, S2)
O2 Sensor Voltage (B2, S3)
O2 Sensor Voltage (B2, S4)
Battery Voltage
Happy CL-S Pilot
The downside, it logs 4 values at once at a rate of 1 sample each 5 sec. That is too low for a drag racing that ends in 15sec! It is great for keeping an eye on commuting and long trips.
I wished if it was able to do 1 sample each 100 ms! or 10 sample per sec. It is flashable firmware and software can be upgraded. Let us hope the sampling hardware is fast enough.
Nasuhua
Nasuhua
Happy CL-S Pilot
Code:
Vehicle : 2001 Acura CL-S Parameters CarChip : NNH's CarChip E/X Parameter 1 : Vehicle Speed Every 5 Seconds Parameter 2 : Engine Speed Every 5 Seconds Start Time : 6/16/2004 22:47 Parameter 3 : Engine Load Every 5 Seconds End Time : 6/16/2004 22:56 Parameter 4 : Intake Air Temperature Every 5 Seconds Duration : 0:09:13 Parameter 5 : Coolant Temperature Every 5 Seconds Idle : 0 to 45 MPH : 46 to 60 MPH : Comments : First initial walk around the block to test the CarChip E/X 61 to 75 MPH : Over 76 MPH : Title : View / Trip Log / Trip 1 / Table Elapsed Time Speed [MPH] Engine Speed [RPM] Engine Load [%] Intake Air Temperature [°F] Coolant Temperature [°F] Distance : 4.7 Miles 0:00:00 0 781 33.73 145.4 149.0 Average Speed : 31 MPH 0:00:05 0 779 32.16 145.4 150.8 Maximum Speed : 70 MPH 0:00:10 0 787 31.37 143.6 152.6 0:00:15 0 771 31.37 143.6 152.6 Hard Brakes : 1 (Between 0.51 G and 0.71 G) 0:00:20 0 767 31.37 143.6 154.4 Extreme Brakes : 0 (Over 0.71 G) 0:00:25 0 763 32.16 143.6 156.2 Hard Accelerations : 1 (Between 0.28 G and 0.48 G) 0:00:31 0 750 31.37 143.6 158.0 Extreme Accelerations : 0 (Over 0.48 G) 0:00:36 0 774 41.96 143.6 158.0 0:00:41 2 1526 51.76 143.6 159.8 0:00:46 11 1346 46.27 140.0 161.6 0:00:51 14 1144 25.88 140.0 165.2 0:00:56 13 1147 25.10 140.0 167.0 0:01:02 12 1066 27.84 140.0 168.8 0:01:07 7 1772 53.33 138.2 170.6 0:01:12 19 1610 39.22 136.4 172.4 0:01:17 28 1764 20.78 134.6 174.2 0:01:22 28 1323 19.61 134.6 176.0 0:01:27 11 928 55.29 136.4 177.8 0:01:33 13 2223 75.69 132.8 179.6 0:01:38 29 1243 28.63 129.2 181.4 0:01:43 32 1207 21.57 129.2 183.2 0:01:48 31 1352 61.57 131.0 183.2 0:01:53 34 1358 17.25 129.2 183.2 0:01:58 32 1065 20.78 129.2 183.2 0:02:04 24 825 32.94 131.0 181.4 0:02:09 15 1814 67.84 131.0 181.4 0:02:14 19 1500 48.24 129.2 181.4 0:02:19 22 1538 47.06 127.4 181.4 0:02:24 24 1632 52.55 127.4 181.4 0:02:29 29 1209 18.82 127.4 181.4 0:02:35 32 1093 27.84 127.4 183.2 0:02:40 35 1544 54.51 127.4 183.2 0:02:45 35 1324 30.59 127.4 183.2 0:02:50 34 1410 56.08 127.4 183.2 0:02:55 37 1520 58.04 127.4 183.2 0:03:00 37 1315 19.61 125.6 183.2 0:03:06 30 929 30.20 127.4 183.2 0:03:11 21 1655 59.61 127.4 183.2 0:03:16 25 2005 65.10 125.6 183.2 0:03:21 35 2351 35.69 122.0 183.2 0:03:26 39 1514 34.90 122.0 181.4 0:03:31 39 1632 56.86 122.0 183.2 0:03:37 42 1791 63.92 120.2 183.2 0:03:42 43 1772 56.86 120.2 183.2 0:03:47 43 1788 59.61 118.4 183.2 0:03:52 42 2333 80.78 118.4 183.2 0:03:57 48 2398 60.78 114.8 183.2 0:04:02 47 1677 18.82 114.8 183.2 0:04:08 40 1670 55.29 116.6 183.2 0:04:13 40 1742 64.31 116.6 183.2 0:04:18 43 1650 36.47 116.6 183.2 0:04:23 43 1691 30.20 116.6 183.2 0:04:28 45 2010 66.67 118.4 183.2 0:04:33 53 2232 89.02 114.8 183.2 0:04:39 60 2426 79.22 113.0 183.2 0:04:44 68 1928 19.61 109.4 183.2 0:04:49 66 1781 47.06 111.2 183.2 0:04:54 63 1709 72.94 113.0 183.2 0:04:59 62 1676 67.84 113.0 183.2 0:05:04 62 1724 28.63 113.0 183.2 0:05:10 63 1798 65.88 113.0 183.2 0:05:15 66 1842 56.86 111.2 183.2 0:05:20 68 1900 16.86 111.2 183.2 0:05:25 65 1734 18.04 113.0 183.2 0:05:30 58 1509 19.61 113.0 183.2 0:05:35 53 1452 20.78 114.8 183.2 0:05:41 53 1532 75.69 114.8 181.4 0:05:46 56 1478 19.61 113.0 183.2 0:05:51 52 1413 18.82 114.8 183.2 0:05:56 50 1388 18.82 116.6 183.2 0:06:01 46 1212 26.67 116.6 181.4 0:06:06 45 1365 79.22 116.6 181.4 0:06:12 47 1211 19.61 116.6 181.4 0:06:17 42 1621 87.84 114.8 181.4 0:06:22 42 1145 17.25 111.2 181.4 0:06:27 39 1248 19.61 111.2 183.2 0:06:32 9 695 36.47 113.0 183.2 0:06:37 0 699 35.69 113.0 183.2 0:06:43 0 685 35.69 114.8 183.2 0:06:48 9 1983 65.10 114.8 183.2 0:06:53 29 2245 34.90 111.2 183.2 0:06:58 22 707 34.90 111.2 183.2 0:07:03 1 714 35.69 113.0 183.2 0:07:08 9 2438 79.22 113.0 183.2 0:07:14 33 2820 80.78 109.4 183.2 0:07:19 43 934 27.06 107.6 183.2 0:07:24 42 935 25.88 109.4 186.8 0:07:29 43 944 25.88 111.2 188.6 0:07:34 43 936 25.88 113.0 188.6 0:07:39 42 1252 56.08 113.0 186.8 0:07:45 42 1251 41.18 114.8 183.2 0:07:50 40 1356 67.45 114.8 183.2 0:07:55 39 1361 47.06 113.0 183.2 0:08:00 37 1162 47.45 113.0 183.2 0:08:05 36 885 27.84 114.8 183.2 0:08:10 29 886 26.67 114.8 183.2 0:08:16 23 2811 68.63 114.8 183.2 0:08:21 33 2139 57.65 113.0 183.2 0:08:26 30 1003 25.88 111.2 183.2 0:08:31 15 1978 70.20 113.0 183.2 0:08:36 21 2019 41.18 111.2 183.2 0:08:41 22 1737 18.04 111.2 183.2 0:08:47 10 686 35.69 113.0 183.2 0:08:52 1 756 34.90 113.0 186.8 0:08:57 1 1242 42.75 114.8 188.6 0:09:02 1 681 35.69 116.6 188.6 0:09:07 0 686 33.73 116.6 188.6
Happy CL-S Pilot
I formated the expprted text to a nice looking excel file and then did a copy and paste.
Sure it works. First to notice, Coolant temp will stabilize at 183F, Air Intake temp arpund 116F, ambient is 68F. and min engine load of 30% even at idle!
Nashua.
Nashua.
ooo man some psychos gonna put this on his gf car or something or it would be a good way to keep tabs on your kids to see how fast they go in your car(for the beatdown later)
Happy CL-S Pilot
This is one of the intended uses of this logger! If you are drving a corporate car, this is the big brother watching you all the time.
Nashua.
Nashua.
Nashua.
Happy CL-S Pilot
Remind that is not an OBD-II Scanner. Like I cannot watch in real time what is going on. For tunning this cold be a better option: http://www.obd-2.com/
Happy CL-S Pilot
My email to CarChip Tech Support
Hi,
I just bought your amazing SEMA Award Winning CarChip E/X. However, after doing the inital setup and then the first test drive with the chip installed, I found out the fastest sampling rate at 1 samples per 5 seconds is too low!. The quality of the sampled data is ONLY usefull for slow varaying engine parameters like Coolant Temp and Air Intake Temp.
On the other hand, at a max sampling of 1 per 5 sec, the quality of the samples for engine parameters such as RPMS, Throtle Position, Engine load, even vehicle speed is very bad. The frequency of such signals is high and the sampling will result in under sampling and the sampled signal would be Aliased. The result would be a meaningless data captured!
For example, while braking hard, say my car can go from 40 MPH to 0 in 4 sec... the whole desceleration event would be lost and not captured at all if the event happend in between the samples at 0.2 Hz!.
That is is not accepatble at all!
Please could you include in your next software release an option to increase the maximun sampling rate to say 10-25 per sec?
It is the fact that current OBD-2 devices can stream data at rates of exceeding 25 samples per second.
Thanks a lot.
Regards,
NNH
Thanks a lot.
Regards,
NNH
Happy CL-S Pilot
Now, I am capturing Time, Speed, RPM, Throtle Position (instead of the engine load), and Intake Air Temp (usually 30F higher than Ambient!!!, why?) and Timming Advance.
Nashua
Nashua
Happy CL-S Pilot
I would love to see the DEi Cryo Air Intake freezer on my CLS!
http://www.designengineering.com/pro...asp?m=sc&cid=1
nashua, sorry i missed this thread. You should have pm'ed me. my bad.
Yeah, thats way to low samples a second. How do you have it connected? diagnostic port?
OBD II loggers are pretty expensive but i think they have software available to buy with the use of a palm pilot.
Hmmm, i should investigate this. Could you post a picture of how the harness you have to connect to your car looks like, or your connection?
I know they have obd II software, but i'll need to know if they harness they make for it is the same, or even adaptable. I'll check it out though.
also, that intercooler sprayer for my rally car would be so dope. pretty inexpensive too, although i'd probably need a bigger tank.
Did you drive it on the highway for extended periods?? That would cause the temp to drop a bit closer to ambient; maybe within 15 degrees. The additional airflow is what helps there.
I did a test last night which I will report about further later on today. But I ran some ice in the IC reservoir and with my garage having a temp of about 95 I was able to see just above 70 from the IAT.
What sucks about the timing advance it that it is only part of the piece. It is what the ECU looks up for an advance value. If there is any knock detected, timing is retarded through the knock retard value and is not visible.
There are several PALM units available and are not that much. But you do have to have a portable device first. The software is also reasonable but once again, you have to have the device first and in this case a laptop. I have a laptop dedicated to this sitting on my workbench with a wireless connection so I can get on line while turning wrenches.
Happy CL-S Pilot
Lame response from the tech support guy... Anyone can heck the software?
Dear NNH:
A faster sampling rate is only possible with certain communication protocols.
5 seconds is the most frequent rate we can provide which is reliable for all supported protocols.
Regrettably,
Brian Carpenter
Technical Support Representative
Davis Instruments
(510) 732-7814
Don't forget to check the FAQ's at our website, http://www.davisnet.com/support/weather/faq/index.asp
Dear NNH:
Regrettably,
Brian Carpenter
Davis Instruments
(510) 732-7814
Hi,
Thanks a lot.
Regards,
NNH
Thanks a lot.
Regards,
NNH
Happy CL-S Pilot
now, I will be using this data logger to keep an eye on the CAI efficency, drving at around 70 MPH the IAT is still at least 20F above Ambient Temp!... Shouldn't be cloaser to ambient Temp at crusing speeds?
Nashua.
Nashua.
Happy CL-S Pilot
dets,
It is just a chip that you plug immediately into OBD-2 port which is right below " not an ash tray thing" you pop the plastic tab, plug the chip and then put back the plastic tab and you are golden to go. Once back from your trip(s), you unplug the chip get it connected to your PC via a serial cable , download the info and you are can browse the data as mych as you like.
Here is a link to the site: http://www.davisnet.com/drive/produc...p_products.asp
Happy CL-S Pilot
My response:
Brian,
I noted that while logging an Accident event, The CarChip EX is sampling at rate of 1 sample per sec. True it is only 1Hz and not 25 Hz but it is still better that 0.2Hz. Is it possible to email me a special version of the CarChip E/X software with higher sampling rate so I can beta tested on my Acura CL type-S?
If it works that is great, if it does not, then we only tried!.
Thanks,
Brian,
Thanks,
Dear NNH:
Regrettably,
Brian Carpenter
Davis Instruments
(510) 732-7814
Dear NNH:
Regrettably,
Brian Carpenter
Davis Instruments
(510) 732-7814
The Screeching Toyo's
NNH,
How do you think this would work on one of the "Legendary" Sactown runs???
Every 5 seconds might not be too shabby. Every second would be off the hook!!
I would love to see all the hard braking and acceleration marks I would get on
one of our runs!!!! Keep us posted!!!
Happy CL-S Pilot
This is a cool document: http://www.nology.com/pdfandzipfiles...rlocations.pdf
dets,
the obd II data loggers that i know use a program on a palm pilot that basically reads the info at about 30 samples a second and with all different types of engine parameters. You could delete "check engine" lights and do all other types of fun stuff including purging injector solenoid. Now this program is for 2nd gen DSM's but i haven't asked yet whether or not the software could be applied elsewhere. i'll check.
1 Dog, 2 Cats and a G-Pig
At work we hook our laptops directly to the car's computer and get all the data in realtime and have some select parameters displayed on the heads-up display... They're all test cars though and it is a bitch to set them up that way, but very very cool to look at and you have the data straight on your laptop to play with.
Adventurist.
The members of the VW/Audi community can buy this cool little progam that you can hook up through any computer and monitor every sensor real-time. Simply Plug-n-Play and Only $200. I have the older, serial-cable type. Now they have USB, which is awesome. Check it out: www.ross-tech.com
Now, if someone was willing to program and create a similar program for the CL, that would be
Happy CL-S Pilot
Happy CL-S Pilot
Today, I did a trip to Logan Airport using my 99 Toyota Sienna. I used the CarChip for the first time in the sienna. The intent was to recond the IAT while drivig.
I was astonished to find out he whole trip to logan, the IAT was consitently around 82-84F that was way better than our so called CAI!!!!. on Our CLS with CAI, IAT was at least Ambiant Te,p +30F (or around 95F) our Cold Air intake may be more free flowing but it it is not a Cooler intake. The Injen tube is made fro Al and is good conductor for the heat, so I believe it is traping more heat from the engine bay and heating up the whole intake charge! I may resort to a thremal wrap or replace the whole intake with a plastic tube.
Remind you on the Sienna, I do have a K&N Filter but is still factory air box.
Nashua.
Nashua.
Happy CL-S Pilot
I may need to order this: http://www.designengineering.com/pro...sp?m=sp&pid=33
Anyone know where I can get the best deal on this item?
