HVAC??'s Wayne Jens Ac Service Help
This morning when I got into my car, none of the heating, a/c, or rear window defroster controls worked. This is the second time in like a month or so that this has happened. I have had the car since July of 2001, and I have about 21,000 miles on the car. The radio and the clock work fine. I pull the drivers side fuse panel off and pull fuse #3, a 7.5A fuse, and see if it is OK. It was both times. I plug it back in and then everything works fine!!
Has anyone else had this happen???
Is there a service bulletin on this???
Do you have any idea why it would do this??
Any and all help would be greatly appreciated!!!
THANKS!!!!
THANKS!!!!
www.drippinwet.com
not sure, haven't heard of a bulliten but jens probably sees more of those than me, have it looked at and also was everything turned off when you turned off the key, or was everything on auto? - the info might be of help
Cajun Gumbo Man
Why don't you call Wayne ? I have several times and he always helpful........just my 02 cents.....
