How often to change the oil on a Honda/Acura?
#42
nothing's wrong with the oil. but there must be another choice other then fram. STP, pennsoil, any purolator filter, wix, K&N, bosch are all better then fram.
Amsoil is good stuff. I think they said their interval is 25k and i wouldnt have a problem running it to 25k. I would however check the oil to make sure your not burning too much to go below the min mark.
remember, if your running extended intervals, the filter is just as, if not more, important then the oil. choose a high quality filter.
What do you guys think about this oil? Change frequencies that is. I was about to buy some. I was thinking of changing at 15k instead. I never bought into Mobils extended stuff, but this is amsoil and I know they know their stuff...
http://www.amsoil.com/StoreFront/sso.aspx
#43
#45
lowrd on tein CS biatch
get quaker state filters.. I ran those for the first 35000kms on my car and it was running fine.
Now I just bought the 15 mobile 1 off the BM so i will be upgrading my oil filteration, but really..
first thing that's important synthetic oil
2nd thing change frequently 3.5K-5K (i do 5000kms)
3rd least is the oil filter (if u got good oil in the car and the motor has been maintained properly and u change ur oil frequently)
ASK URSELF HOW CRUCIAL is a SUPERIOR oil filter...
probably not much at all in the grand scheme of things.
so if u cannot get anything but the "not so good filters" then don't lose sleep over it cause it don't matter.
On my last car (the ford probe) I used fram ONLY for 100000kms and no issues. so, u know how it is... one person has a problem, is goes to the news, we all hear it for like 6 months and then we deem that product to be faulty.
Remember it takes years to build a reputable name for a company/business/product and only takes ONE MAJOR incident to ruin it.
(kinda funny how the world is... the only thing that is easy is death/destruction... everything else u gotta work ur ass off)
#46
B A N N E D
#47
I feel that unless your racing or towing (not likely in a CLS)I mean real racing! Then changing your oil every 3000 miles is like changing you light bulbs in your house before they go out. 3000 miles was the original recomendation of the oil companies. And how far has oil come in 80 years? Pretty far if you ask me. Just my thoughts.
#48
B A N N E D
yes oil has advanced over the years, but engines have become alot harder on it with alot higher power ouput with smaller displacements (30 years ago 1 hp per 1 cubic inch [or 61 hp per liter) was alot of power; nowadays 100 hp per liter is really commen [1.6 hp per cubic inch]) so they also hotter (the emissions improve too when they run hotter), they also rev higher too
but also engine compartments have become smaller and tighter around the engines so there is less air flow around them, which also makes them run hotter
also the oil sumps on modern engines have become quite a bit smaller, so each oil molecue gets more strain put on it in a shorter period of time, because there are not as many oil molecues to take the strain, so the oil runs hotter
also the filters have become smaller due to space constraints from smaller engine compartments, so they do not take as much to plug up (but modern engines do run cleaner, and are sealed better, so this is kinda offset)
people also drive their cars alot more nowadays in stop and go traffic, and short trips, which is torture to the oil
so i still like to change my oil at 3,000 miles due to the above
#49
an adult perspective
I changed the oil in my CL every 7,500 miles on the dot. My next service would have been the 225,000 service. Not one engine related problem during the time I owned it. No synthetic ever used, just the manufacturer recommended oil/filters.
#50
#52
they changed oil alot more often 80 years ago, alot of people proably never even drove 3,000 miles in a year,
What is your source for this info? Is this proven fact? Source? Or is this just your opinion?
I would guess that engines today are easier on oil as they have become more efficient. And the oil has become stronger. This is just my thoughts though, not proven fact.
#53
that is under "normal" driving conditions which 90% of the population doesn't meet, so they should follow the "severe" maintence scheadle (spelling?) which states 3750 miles in the owner's manual, but still does not hurt to do it early, which is also a good time to checks the brakes, tire pressures, and such, to make sure every thing is in tip top shape
btw: i also do it every 3k on mine, and i am an auto tech, so i also do what i preach, and i use a quality oil too (castrol)
#55
Sorry color doesnt mean its going bad. It means its doing its job. The ONLY way to know if the oil has life left in it is to have it tested!
#56
So if you dont change it more often your motor probably wont make it to that mark? Kinda funny how i was on the extreme end of extended mark and my first motor (only reason it got pulled was for the 6 speed/types swap) was at 220k and never burned any, bearings were perfect and compression was near perfect with every cyl and in spec. Unless something freakishly catastrophic were to happen it would have easily made it another 200k.
#57
I think It's a waist of money, time , and good oil to change synthetic more often than 5000 miles. And I think that 5000 is way into the safe zone. If I had to go 7500 I would not feel like I was hurting anything at all.
But I would like to know where friesm2000 got that info.
#58
#59
B A N N E D
they were/are more genealerzartions (spelling?), but from working on cars for a living...
from http://www.project.org/info.php?recordID=146
can't seem to copy and paste picture so go to link (remember 1980 os so was the oil embargo)
from: http://www.nhtsa.dot.gov/cars/rules/...erCarFleet.htm (i deleted some things not neccessary, so look at website for full thing) and can't seem to paste tables on here
look at the blue writing especially
could only
cars were also heavy back in the day, then lightened up some due to thinner sheet metal and stuff, then started to regain weight due to safty features and other design requirement like creature comforts
MODEL YEAR
CURB WEIGHT, LB
EQUIVALENT TEST WEIGHT, LB
N/V
DYNO HP
DISPLACEMENT, CU.IN.
S.I. DPL, CU.IN.
HP/CURB WEIGHT, HP/LB
CID/ETW
TFC/IW, GAL/MI/LB E-5orts
ENGINE HP
working on the others, what to post first so i don't lose it
also getting kinda late
![Sorry](https://acurazine.com/forums/images/smilies/sorry.gif)
MODEL YEAR
CURB WEIGHT, LB
N/V
DYNO HP
S.I. DPL, CU.IN.
CID/ETW
ENGINE HP
#60
could only
MODEL YEAR
CURB WEIGHT, LB
N/V
DYNO HP
S.I. DPL, CU.IN.
CID/ETW
ENGINE HP
MODEL YEAR
CURB WEIGHT, LB
N/V
DYNO HP
S.I. DPL, CU.IN.
CID/ETW
ENGINE HP
But I understand you said "more like generalizations".
#61
B A N N E D
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
and the generalizations are that every engine design is different and manufctors have different standards for designs, but in geneal follows what i said with smaller sumps, filters, tighter engine compartments, etc. the newer the MY's
like tighter engine comartments, they got alot more shit to pack under there nowadays, and aerodynamics play a huge role now for keeping the hood low and sloped which takes away any spare room
#62
Ok I found a great article. I did not research who wrote the article, so I will not say this is the bible to oil changes.
http://neptune.spacebears.com/cars/s.../interval.html
Anyways, read the entire thing. The last two paragraphs sum it up.
They go on to say that a 3000 mile change "are rubbish and worthless".
It's makes for great reading.
To the OP this should help answer your question. But like I said, I know nothing about the authur.
I'm sure there are many great articles on the subject.
I would usually go looking for evidence to dispute what is in that link, just to read both side of the story, but im tired and agree with the finding. I'll look later for reasons to change every 3000 miles.
#63
also remember that people bought cars after WW2 and move out to the suburbs more and had to drive further (also it was near the end of the depression
80 years ago)
aerodynamics also take a HUGE load off the enigne.
I don't know of any manufatures that still say to change the oil every 3000 miles. Of course I have not really gone looking at owners manuals.
Shoot, my wifes Pacifica with a 3.5V6 252 hp 250 tq and weighing in at 4600 LBS with 19 inch rims and AWD recomends every 6000 miles under normal driving (in other words no towing), and thats on Dino oil!
#64
Well i tried to find good reason to change evey 3000 miles and only found more reasons not to.
http://www.ciwmb.ca.gov/UsedOil/OilChange/
http://www.sfgate.com/cgi-bin/articl.../BA1EUUCL9.DTL
Pretty sure I'll never do a 3000 mile change again.
#65
B A N N E D
theory 2: also like what it says to the "oil analysis" way, by the time you pay for the testing you might as well have changed it, but i can definetly understand it on a much larger engine which takes ALOT more oil so it is alot more $$$ just to change the oil (like where it takes gallons of oil just to change it)
theory 3: without accurately measuring the oil, the life of it can easily change when you start out with a different oil then stock, but also it is assuming it runs exactly the same on every engine, and proably the same maintence, and stock parts like airfilters (cheap filters do not filter as good and can allow dirt into engine which causes increased wear and more oil contamination
theories 4, 5 ,and 6, you still need extremely accurate numbers and (which are not so easy to get and can quite easily change due to wear and it's maintence history) and some math, so those are kinda out the window
#66
B A N N E D
also to make sure every understands i am talking about changing convential oil at 3,000 miles (no mention of synthetic in OP's post), and i am fine with synthetic (with a quality filter) at 5,000 miles (the added cost of synthetic basically eats up any money saved by going with it, biggest thing is the longer change intervals, especially if you drive alot)
#69
B A N N E D
While it's true that many new cars don't require oil changes every 3,000 miles, he said, not everyone drives a new car. The average American vehicle is 10 years old, he said, and many older cars require 3,000-mile oil changes as stated in their manufacturer-issued manuals. Even many newer cars, he said, require more frequent oil changes if driven under more strenuous conditions, including off-road, towing vehicles, those carrying heavy loads, or vehicles in dusty areas.
another from second site:
The agency, assigned to reduce waste and keep used oil out of landfills, water bodies and groundwater, launched the campaign after research found that 73 percent of Californians change their oil more frequently than recommended by the manufacturers of their vehicles - most of them at 3,000 miles.
yeah right 73% change there oil at 3000 miles, maybe like 10% if that, and i know we also recycle as much of the used oil at work as possible (except for those couple of drops on the floor when the plug is pulled, i am actual pretty clean with those, and the oil left in the filters from draining overnight) (also pulling every filter is not the neatist cause it lets oil get over the block, but we have a big enough oil drain that it can basically catch it all, and then we clean it down afterwards in the area it spilled, so nothing is left on the block to drip later)
and yes better aerodynamics does reduce the load, but people also drive faster and accelerate harder nowadays, which basically offset the aerodynamics
x2, and i got access to a lift so even easier for be, but even before that i still changed my oil at 3k
#70
B A N N E D
looks to be some decent reading of oil filters:
http://people.msoe.edu/~yoderw/oilfi...ilfilters.html
i have not read the whole thing yet, i just started but wanted to share first
also maybe: http://www.knizefamily.net/minimopar...ers/index.html
#71
B A N N E D
#72
Well ... here's a consideration that I think would be a bit nearer and dearer to the wallets of the younger demographic into whose hands these cars seem to have found their way into ...
My last 'service' was conducted at the 217,500 mark. Lets back this up to 210,000 just to make the math easier. Now, changing the oil at the 7,500 mark like I did throughout my ownership of Y2K3CL-S, I performed 28 oil changes. Doing this every 3,000 miles would have been 70 oil changes ... basically 150% more often. Based on the cost of oil, oil filters, etc, ... looks like there might be a bit of money left over for other mods if one were so inclined. And I think theres enough evidence that these engines are designed to last if manufacturer recommendations are followed. However ... if you've got that the money to blow, then don't worry about what anybody else says or does.
#73
#74
ABP-KBP-CBP & ME
I realize that our engines can go 7500 mile intervals between oil changes but personally I get it done every 3-4k and I can definitely tell the difference in performance when its initially done so I choose not to string it out to the max. I get it done at the dealer and they use a synthetic blend.
#78
B A N N E D
still won't completely warm it up all the way, but yes it will help
i was even thinking about one for mine, just so i can have heat a little sooner
(i know, i am a skinny white boy though![Why Me](https://acurazine.com/forums/images/smilies/whyme.gif)
), and it does not get nearly as cold here as where the mooses are
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
![Canada](https://acurazine.com/forums/images/smilies/canada.gif)
#79
Why? Unless you have your oil analyzed and its pointing to changing it sooner there is NO reason to do so. If you plan on running extended intervals have it tested after 7500k and see what type of condition it is in then and adjust your next oil change accordingly
#80
Whats up with RDX owners?
Theres was someone on the 8th gen Civic forum that has over 400k miles on his 2006 Civic (seriously).
He changes his oil every 20k miles. He runs Amsoil. He sends a sample in for testing every oil change. Theyve told him to run 25k miles per oil change, but he still does it every 20k.
I used to do it around 3k miles, but now Im doing every 5k. Its still a waste as Im most likely not using the entire life of the oil, but I just dont feel comfortable doing it longer due to driving conditions, the weather fluctuations the past week (70* Thursday, 30s and snow Saturday
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
EDIT - Found the link http://www.8thcivic.com/forums/mecha...strong-41.html
He does 150k a year
