how does this performance mod sound?
I am in Taiwan now for my vacation.
Today i checked out an auto shop ran by a cuz's friend. he does some mod himself (he drives a TC 93 MR2), and says one of the easiest mod i can do now on the CL-S is to put in a "fuel injection pressure regulator".
Basically it is a little device (with a pressure meter) that "forces" more fuel into the engine (and less flow back to the gas tank), causing the RPM to rise more quickly. That thing costs about US $100. Does anyone know if this will work on the CLS?
2001 Silver CL-S
Comptech springs, sway bars, 35% Madico smoke tint, gutter guard front grill, hardwired V1, Xephyr CAI, PIAA 19172
2001 Silver CL-S
sounds interesting. some gran tourismo type shit
2001 Acura 3.2 CL Type-S
San Marino Red (Navigation)
PIAA 19173 Ion Yellow Fogs • Valentine 1 • SilverKnight Grill
Xephyr CAI • Comptech Springs
Wouldn't that make it run a little rich.
97 2.2 Cl
H&R sport springs
Clear signals
Pioneer P8000 cd player 4 12" Kicker Comps
Old school punch 100
Orion XTR400
Focal Polyglass 165V
97 2.2 Cl
H&R sport springs
Clear signals
Orion XTR400
would it work as well for a Naturaly Aspired engine as it would for a turbo?
CL-S
White/Ebony/Navi/Spoiler/Visor/Full Bra/Mud Guards/Acura Car Cover/Tint 20%,35%,5% on Sun Roof, Rockford 250a2 Amp w/JL10w6 / K&N Drop in Filter.Polarg m-6.
Comptech Headers,Springs,Sways, Eurolite Xenon Crystal high beams.Polarg m6
gtech 0-60 6.03 w/ 438 pound load. preheader.
CL-S
Here is AEM's fuel pressure regulator. Unfortunately they currently don't make one for the 99/00/01 TL/CL
1999 Satin Silver Metallic 3.2 TL w/o Navigation
- 18x8 Racing Hart C2s with 225/40ZR18 Dunlop SP Sport 9000
- Comptech Springs, Sways, Exhaust, and Headers
- Red AEM CAI w/bypass valve
- A'PEXi Digital VTEC AFC
- Denso Iridium Plugs
- Custom Mugen Grill
- Inspire Tail Lights
- Factory Underbody Kit and Spoiler
- Clifford Intelliguard 9000 Alarm w/SmartWindows II
- Alpine 6 disk CD Changer
- BEL 945i Cordless Radar Detector
- Burlwood Shift Knob & Trunk Tray
- 20% tint
Do they make one for the Accord V6?
'01 Black/Tan CL-S w/ Navi & spoiler
AEM CAI
Comptech headers & sway bars
Toyo Proxes T1-S 235/45ZR17 tires
15% tint, Infinity Perfect sub/PPI amp
'97 Acura Integra LS
"You don't need a shopping cart wing to go fast..."
AEM CAI
Mchtypes used on on his car, and got 0 performance out of it. I believe this is true. Thats why people who lean out the top end get more power. Our cars are made to run richer then leaner as the revs go up. FPR will not be effective, unless we have a SC.
Spiro
Black/Black 2001 CL-S
Random Technology Cat
RED AEM CAI
APEXi V-AFC
Polarg M6 Roadlamps
Spiro
RED AEM CAI
APEXi V-AFC
Polarg M6 Roadlamps
Don't bother -- sorry ...
Silver 2001 CL-S with NAVI
- Mud guards
- Wheel locks
- Toyo T1S 235/45ZR17-97W* Proxies on 17x8" SSR Competition wheels (48lbs less than stock)
- Kevlar/SS Brake lines w/Brembos?
- Comptech headers & sways
- Silver AEM CAI
- 10 coats of Zaino magic
The thing to keep in mind here is that the ecu in a modern car controls injector duration or in other words how much fuel the injector is allowed to inject at a time.if you add a device such as this what the ecu will see is a rich mixture which it will attempt to lean ou by reducing injector "on time" untill it can no longer compensate.When this happens it is said that the ecu is off it's map and turns on the check engine light most likely throwing a code for excessively rich mixture.Jens
1992 mazda Miata lowered with Eibach springs KYB AGX adjustable struts Sparco racing buckets 4 point safety harnesses Momo steering wheel lo profile headlite system with PIAA superwhite bulbs Custom audio system Custom gauges Jackson racing supercharger with header and Greddy cat back exhaust and a ton of other stuff 2000 Honda Civic on APEX coilovers Full Alpine Audio system factory fogs with Piaa bulbs Catz ZETA high beam headlamp system H.I.D. Xenon low beam tinted, custom taillites and on and on
Is it good to run a Fuel pressure regulator when using Nitrous?
Y2K SaTiN SiLvEr BoTTleFeD 3.2TL
-AEM Short Ram intake
-AEM Tru-power pulleys
-NOS 70 shot wet Nitrous System
-Magnaflow exhaust
-Ground Control coil overs
-BLITZ 1.3 kg radiator cap
-Factory underbody kit and Wing
-Mesh grill
-Body color door handles
-20%/35% Llumar Platinum tint
-Räzo Shifter
-2 Rockford 10" XLC subs/Boss Audio CLR60 amp
-Magnaflow exhaust
-Mesh grill
-Räzo Shifter
You won't really need a FPR on ur cars. Max hp increase is 1-2 dynoed. It works good on turbo or nitrous setups or even an agressive cam setup. Well pretty much anything that requires more fuel to go to ur injectors. Don't think of it as a performance modification. Think more of something to help control fuel pressure manually. The fuel settings on a vtec controller can only do so much.
1997 Acura 2.2 CL (5spd)
rubber tires, windshield wipers, headlights, horn, steering wheel, BRAKE PEDAL, clutch, brake pads, driver seat, passenger seat, back seat, front windshield, rear windshield (with defroster), lumbar support, cruise control, intermitent wiper control, sun roof (tinted), engine, pistons (only 4), emergency brake handle, trunk w/ tools, spare tire
<font face="Verdana, Arial" size="2">Originally posted by spiroh:
Jens,
Would the V-AFC also make it to show a check engine light?
Spiro
</font>
Jens,
Spiro
</font>
- Mud guards
- Wheel locks
- Toyo T1S 235/45ZR17-97W* Proxies on 17x8" SSR Competition wheels (50 lbs less than stock)
- Silver AEM CAI
- 12 coats of Zaino magic
- Stainless Brake lines coming (Brembos?)
- V1 planned
hey i got some. a fuel pressure regulator is a good mod if u have mods.
heres some intresting info from the SPORT COMPACT CAR magazine in their special honda tuning edition for 2001.
pg 70
Conventional wisdom dictates that an upgraded fuel pressure regulator is only needed on an engine w/ forced induction. Adequate fuel delivery under boost is crucial to ensure your engine doesn't end up as shrapnel all over the road.
However, a high-flow intake, header and exhaust combo also frees more airflow in and out of the engine. At WOT, it's not uncommon for engines to be running lean while breathing through a high-flow intake and exhuast.
1997 Black Acura 2.2 CL
Currently-
PIAAs Everywhere, PIAA 1700X, Custom Grill, Clear Corners, OE Spoiler,
5% Tints (Limo), HKS Super Dragger Exhaust, AEM CAI, Venom 400
De-Badged
Comming Soon-
Headers or Ignition, Front Lip
http://members.home.net/vx16
pg 70
Currently-
De-Badged
Comming Soon-
We have experienced some cases of check engine lights illuminating when these decices are used.Keep in mind thta these V-AFC devices are there to help you tune a car that has been modified.The addition of CAI or exhaust work is not enough of a reason to install one of these units.The factory ecu has ample programming in it to accomodate these mods.Jens
09-15-2015 06:44 PM
Rcelestino93
09-11-2015 12:15 PM
