How do you mount your front license plate?
My front license plate bracket is scratching up my bumper.
I am thinking about getting both bumpers repainted, but its like $375 each!
Any ideas on how to mount the front license plate so that this doesnt happen? Post pics if you got any interesting ideas!
Here is what mine looks like...
Whats up with RDX owners?
Pick up some angle iron and fab up a mount. You can mount it lower on the bumper, so it isn't pressing on any painted surface. You may be able to use the stock bolt holes or you can run the plate offset, you just need to drill holes. I dont run a front plate on my car anymore, but the scratches are still there.
If you get the right hardware you should be able to use the two holes currently used by the stock bracket (they are underneath, not in the facing of the bumper).
If you went for the offset look then yes, you do need to drill.
hmm.. ok. sounds interesting, do you have any pics so I can get a better idea of what you are talking about?
Will it fit in the space without hanging over the bottom of the bumper?
I'd like to see how it looks.
Not a doctor
1 Post
somebody at a meet once told me that you can use the stock bracket upside-down if you get longer screws. i think i'm going to try that this summer; i'm tired of getting pulled over for not having a front plate
Here in CA, you need a front plate. The bracket is held on underneath the bumper so there shouldn't be any holes through the bumper cover. I got two L brackets, drilled some holes and mounted it from the bottom using the existing holes from the original bracket. The plate and frame hung down too low so I cut about an inch from the top so it's even with the front lip. The plate is bent to the same angle as the bumper and I sanded the white paint from the letters on the frame.
The only problem is doesn't hide the scratches that were already there.
I really need to clean my car.
I Wanna Beer
Have fun with the ticket you'll get for not having it. I went a year before getting one but the $135 ticket made me put a front plate on after that.
There is one that slides from underneath and flips up.
That's what I plan on getting.
When you don't require a front plate, then it fips down and then can be slid back into the bumper.
Didn't have time to look up the model...but that's what I am going to get.
You had to cut the actual license plate to get it to fit correctly?
nf3d0149ab
If you find a link to that bracket please post. I am interested in seeing it.
I did that with my Prelude. It worked well. However the CL bracket is angled, so it may not work without cutting some of it.
Back in the old days someone put the stuff that people use on the edge of car doors around the backside of the license plate frame so it didnt' scratch the paint...
StreetKA
Where you getting it painted. I'd like to get my bumpers done, but i think its alot to spend $700 on bumpers alone. I am in NJ too.
GreenMonster
I was thinking about getting some silicone used for cooking sheets and cut strips to line the back of the bracket. I think it would work if I can get the silicone strips to stay on to the bracket with some strong glue.
Putting something on the back of the bracket isn't going to help. It's the sand and small rocks that get caught between the bracket and bumper cover that scratches the paint. The bracket and bumper cover is flimsy plastic and is constantly moving and flexing. Whatever gets caught between the bracket and bumper is going to scratch the paint.
You need to either protect the paint by putting tape or something on it or move the bracket away from the bumper so it doesn't touch the paint.
http://i19.photobucket.com/albums/b1...g/P1000774.jpg
I put it on because I just don't want to hassled. I've gotten fixit tickets before and it only gives chicken shit cops an excuse to pull you over and run your record, check your registration, insurance and inspect your car. I've even got a ticket for no front plate while my car was parked.
Chamorro
http://i19.photobucket.com/albums/b1...g/P1000773.jpg
yup and now its 25
OP: Like Noah was saying they have the ones that are motorized the company is called swift motorsports. The mototrized one is 2 wires and you use a remote to use it 160 bucks and then they have the other ones that you get out and slide it thats 60 bucks.
A guy from the Bay area has the motorized one and he likes it worth the 160. I was trying to something with mine but it got messed up and if i take it off i will have two holes under my drivers light so when i repaint my bumper next month ill get the swift one
