How do I take the 3 clips off in order to change road lamps?!
Old 12-12-2006, 02:40 PM
itsromy's Avatar
This might be a dumb question. But you know... the clips that secure the splash guard under the road lamps... I need to change the bulbs, but I can't seem to get the splash guard off. Anybody help, please. I'd appreicate it. Thanks!
Old 12-12-2006, 04:07 PM
CLS 6MT Navi
123456SPEED's Avatar
The roadlamps pop out after unscrewing one screw from the grill area. You can also change bulbs by just reaching underneath. I never removed any car parts to change the bulbs.
Old 12-12-2006, 04:26 PM
proffesion...axle breaker
Stealth CL's Avatar
please search sir
look at the very first post the "sticky" second Gen. CL information thread
thank you so much, have a ever so pleasent day
Old 12-12-2006, 05:24 PM
Not a doctor
RYANGP's Avatar
Two different ways.
If you go through the splash guard under the car, use a flathead screwdriver, slide it under the little notch things in the clips and wiggle it until they pop off. I did this the first time i had to go in there, and it's kindof a pain in the ass to get under the car and an awkward position to be in when dealing with fragile bulbs that could potentially break in your face.
The second way is much easier. Take a phillips head screwdriver and find the screw on the side of the lower grill and unscrew it, then reach in and push the entire roadlamp casing out, and unhook the roadlamp cables and replace bulb etc.
Look at the FAQ section.
https://acurazine.com/forums/acurazine-clubs-meets-15/chicago-cruisin-66-car-show-invite-181322/
There you will find most of the information you could ever need and you won't have to post threads asking questions already covered
Also this guy Chod has a pretty good DIY w/ pictures on how to do it the second way
Old 12-13-2006, 01:11 AM
itsromy's Avatar
thanks!
rockyboy
08-04-2024 10:35 AM
02-25-2020 09:57 AM
giovane
2G RDX DIY & FAQ
07-08-2016 10:46 PM
real_mckoy
4G TL Problems & Fixes
09-25-2015 10:49 PM
Aleax
09-11-2015 11:31 AM
Quick Reply: How do I take the 3 clips off in order to change road lamps?!
