Homelink Programing. Can I do this?
Can I program the homelink in the car to open a gate that uses an access card? My complex has a gate & I need to swipe my card at the sensor everytime I go in, or out. Maybe do the programing right when I use the card?
Yeehaw
most apt. complexes have some kind of system so you can't do that. even the ones where you can get a pager remote usually won't let you copy the signal with homelink. I've tried a bunch of times with no success.
Re: Homelink Programing. Can I do this?
Yeehaw
Re: Re: Homelink Programing. Can I do this?
Originally posted by cls6sp03
Technically speaking, you're talking apple and oranges. Homelink uses a coded RF signal to talk to the garage door opener. But the card key is probably a passive smart card (build-in IC chip) that needs to be powered by the card reader via an RF signal and/or magnetic field. The key card could just be the old magnetic strip type. Completely different technologies.
Re: Re: Re: Homelink Programing. Can I do this?
Originally posted by Beetroot
yeah but the way my old apt. complex worked was you slide your card through a card reader, and then that card reader sends a signal (RF I guess) to open the gate. so you obviously can't copy the card reader part, but it might be possible to copy the signal that the card reader sends out to open the gate. If the card reader is hard wired, then your screwed, but if it just transmits a signal then you could possibly copy it.
Chonny
06-07-2007 03:45 PM
AcuraTLSFan
2G CL Frequently Asked Questions
01-19-2004 10:19 AM
