Hey fellas my car temp goes up with ac on too long😩
When I leave my AC on too long the car temp slowly goes up what can it be? Someone told me thermostat I have a 2003 CL type s
I am dumb
Have you checked to see if your coolant level in your radiator is low? There's not really a stick like there is for oil or transmission, but when you pull that cap off (don't open it while it's hot), you should see some liquid floating at the top. If you can, try pouring some coolant into it and see if it over flows, or if it chugs it down. If you're low, you have a leak some where.
I am dumb
However, as soon as you see a leak, stop, and figure out where it's coming from, if it even is a leak.
restricted airflow would be my first guess after fan. is this just sitting that it happens or all the time? is this an automatic by chance?
