Help Zaino
Help Zaino
I applied z1 and z5 and let it sit over night when I wiped it off it seems to me that I am creating haze marke it seems streeked and greasy. should I wash it with z7 wash. I am realy frustrated so i called some detailing plase they said to use a cheese cloth (scince it has holes in it it can pick stuff up better)Please help me with your oppinions.
thank you
thank you
what? cheese cloth NO!
Don't worry nothing bad has happened. The Zanio has just bonded with the paint....this is what it's supposed to do. Ok, the stuff you put on has really caked on there and so it will take much effort to remove it with towels. Make sure that the towels are clean and then go at it again. You will really have to work so don't worry if you get exhausted. If you don't want to do that. Just wash the car again but you will still have to rub all the stuff off. Stick with Zaino!!!!! At first it's a pain but it's so easy now. It took me 8 hours the first time i did it but now it's like an hour or so.
Yea, the haze is normal, your suppose to have it
The next day just buff it down with a huge 100% cotton towel
be sure to cut the tag on the towel so it wont scratch your surface
*bling bling *
*bling bling *
You probably put it on too heavy and it never got a chance to fully dry.
You don’t need to apply ZAINO as heavy as other products.
You don’t give your location so I can’t speculate if high humidity is also a contributing factor.
For the record, I usually use FOUR or FIVE full size bath towels (white 100% cotton) for a complete Z-Tail job.
Wipe the car completely with one towel and then go to another clean one and repeat.
Once you get a good coat on there you will be able to add additional coats in about 2-hours.
Shawn S
I am the ZAINO MASTER !!!!!
Shawn S
