Help!!!! Rear Rotors...cant Get Em Off
yep.... the e-brake might be hanging them up... have to turn the spindle to loosen the e-brake or go inside the armrest and loosen the minor adjustment..
did you get the brass screws off?
Blown is Best
If you have the two screws out and it still won't come off, there are two threaded holes in the rotor that you can thread a bolt into to push the rotor off of the hub. I think it's a 8mm X 1.25. I've used the bolt that holds the brake line to the lower assembly because it's the right thread. It should "pop" once you start threading the bolt in.
BoricuaTL
04-08-2016 01:08 PM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
