Help with evap code p0450
Old 08-28-2014, 12:45 AM
6mt swapped..smart
AnthraciteTypeS's Avatar
Anyone successfully cure this code? I'm not sure what to start replacing. 03 cls 6mt swapped
Old 08-28-2014, 09:21 AM
3.5 psi
gnuts's Avatar
found this: http://www.v6performance.net/forums/...ure-codes.html
might help.
Old 08-28-2014, 01:47 PM
lowrd on tein CS biatch
CL-S progression 01's Avatar
I tried chasing down an evap code for a month, changing parts one at a time. 500 later I brought it to the dealer. 350 later of diagnosing. They put back in the old canister shut valve and then it worked again
Moral of the story, sometimes it's cheaper to bring it to the dlr cause they needed to run all sorts of tests with their computers, multiple times to find the issue. And even still when I got it back a week later the code came back and they had to put back in that old part and then it worked, vs the brand new part. I'd never have solved that.
Old 09-07-2014, 01:18 PM
Eurotrash
Tosh's Avatar
'Canister shut valve'? Is there an official name for this part?
Old 09-07-2014, 02:01 PM
Eurotrash
Tosh's Avatar
Found a DIY for r&r the EVAP canister and shut valve here:
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-evap-canister-shut-valve-replacement-729920/
Old 09-08-2014, 01:24 PM
6mt swapped..smart
Thanks Tosh. Another evap code came on after some more miles P0452 Evap Pressure Sensor. Hoping that's the issue.
I ordered the fuel tank pressure sensor which will be here tomorrow. Will update this thread after install and some miles
Jamus22
06-11-2023 10:08 AM
samson_420
10-08-2015 01:47 AM
Skirmich
10-01-2015 12:59 PM
thegipper
09-28-2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
09-28-2015 12:33 PM
Quick Reply: Help with evap code p0450
