Help - Am I ordering the right bulbs?
Old timer
Polarg M6s to replace the foglights (are those the right ones?).
Polarg M4s to replace the door lights.
Polarg M16 to replace the dome light.(Waiting on this one - too much $$$.)
Do I have the right bulbs? I'm about to order from autocarparts but I wanted verification.
Thanks.
-J
[ 07-08-2001: Message edited by: JRock ]
Thanks.
-J
Originally posted by JRock:
<STRONG>Polarg M6s to replace the foglights (are those the right ones?).
Thanks.
-J
[ 07-08-2001: Message edited by: JRock ]</STRONG>
Thanks.
-J
Not sure about M4, but I vaguely remember others using these for the interior. If it is type 168, you can also use it for the map lights, the license plate, and the trunk IIRC.
For the dome, I used this: http://www.eautoworks.com/html/ORD-L...-2067-none.cfm
(minimax superwhite dome light)
Good luck.
I've used the PIAA 69s for my door and maps ligths, Even had a M6 in the doors for awhile, i got scared of melting something (but no problems after 2 months) Then I used another PIAA striaght bulb for the dome. Heres my question the dome bulble is a lot brighter and whiter, however it was about 3/4 the lenght of the sotck bulb. I had the bend the balasts a little so that then just pinch the ends of the bulb. anyone else have the problem or did I just order the wrong sixe?
Retired. Not available.
Thanks.
-J
Thanks.
-J
you forgot 2 M2s for the reverse lights. They look really nice there.
