Help
Ricky: Drugs > Football
Help Eletrical problem
I just installed my icebox today and it works fine. But for some reason my left lighting is all out. My left headlight my left tail light and my left turn signals dont work, my left corner light works and my left roadlamp is at like 15% of brightness. So i think that there is something interfearing with the power.
I'd have to look at the schematic to see which one, but it sounds like to disconnected a wire harness. Check all of your connections near the box.
Also, you may have damaged a wire which resulted in a short and blew a fuse.
i'm going to check it again i just didtn want to do it last night cause i finished at around 11, the ground was hooked back up i think i might have shorted something because there was a funny smell when i started the car up for the first time.
well it was a problem with the ground wire, i guess i tightened it to much yesterday or something, i had the light switch on and in dif positions the light just turned on so i found a good position and tightened the bolt to the ground wire.
Thank you for your help.
