Has anyone had a problem with their Clutch Masters Kit??
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
I am starting to wonder if my Stage 4 clutch masters flywheel and clutch combo is causing my crank sensor dilema. The 6speeds have 2 crank sensors, one on the crank side and the other on the tranny side. Any input?
refer here for my problem: https://acurazine.com/forums/2g-cl-problems-fixes-70/need-some-help-after-motor-swap-my-6-speed-733464/
Mine is back together and running. I have the stage 1 kit, but I think the only difference is the disc between it and the others.
I also have Razco lightweight pulleys, including the crank. Idle is smooth. Starting is alot grindier than it used to be. I have no CELs, and the car makes mad power above 4000rpm.
sorry for going a little off topic, but i've tried adjusting my clutch pedal to no avail, the nut on the master cylinder just spins with the rod. am i doing something wrong?
1fatcrxnem1
22
06-01-2018 01:23 AM
mugen_kid
11-13-2015 10:38 PM
