H&R sport spring alignment question...
i just replaced the stock springs w/these sport springs. i am using the factory tire/rim and noticed that the right tire seems to be a little off. i read in another thread that an alignment is highly recommended and also that the specs would possibly change than that provided from factory.
does anyone have insight on this? i want to make sure my alignment is done right cause i need these tires to last at least a year.
anyone who installed these springs, what did you do for alignment? who did you go to do it? any probs? concerns? thanx
White Lightning
hey i got those springs installed too. Yes you must do an alignment. I got mine installed at the dealer and they brought it back to specs. But the rear is just a lil bit off but no biggie. Just make sure you rotate your tires more to last them longer.
i know i need an alignment....
my question is, will anyone know what to do to fix it. i recall that they simply look up the specs for the car as it sits from the factory and adjust to those specs. if that is the case, then most alignment shops will get it wrong.
a better question is, where did you get ur alignment done, and did they do a good job???
MrHeeltoe
20
02-23-2023 01:54 PM
emailnatec
29
09-28-2018 04:27 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
