H&R Race springs help
///M POWER
1 Post
I'm thinkin of gettin h&r race springs used just for the front to give my car the raked look and drop the front some more,
has anybody used these sprimgs on the stock shocks, thats what i'm worried about, i dont want to have to replace the shocks soon.
any info or advice would be appreciated
thanks
thanks
Not only will you need new shocks.. but it's not recommended to mix and match springs. You'll have different springs from different companies that have different spring rates installed on different parts of the car... so the handling of the car may be altered in a negative way.
Moderator Alumnus
you might sacrafice handling instead of aiding it if ya do that. Your rear end will feel pretty loose on hard turns. You'll be in oversteer city.
I am running RACE setup for over 9 months know. I think the drop is perfect, I did switch out to Konis though with the change over. If you don't do it at the same time, then it will only be a matter of time till the stocks give out and you'll have to anyway. I also agree with the comment about running the same brand of springs on all four struts.
MrHeeltoe
20
02-23-2023 01:54 PM
emailnatec
29
09-28-2018 04:27 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
