Grille-Tech.com update + pics
#41
Originally posted by Smitty
I don't mind you guys showing interest but I must admit, some of you are really going to fuck things up for this group buy....
Just shut the hell up and be patcient.... You will all be notified and you will see the STICKY on the message board when they are ready.....
#42
DP's for life
Smitty-
I am not sure how things could get screwed up by showing more interest...
I emailed Grille-tech before Delerlict posted this thread...My responce came back late in the day and I posted their responce. It is not my job to speak for Grille-tech, if they respond incorrectly to a request that is their fault not mine. I was merley posting thier responce.
You might want to have a bit more cander next time before you post with such an angry responce.
There is a lot of anticipation for these grills so many people are ready to pull the trigger...Just like you!!!
#44
Originally posted by derelict
Steve my old upper grille (the gutter guard one), is basically diamond style. I'll bring it this sunday if you go... can see if the styles match close enough to use.
Sweet. If we don't end up going I can always run out to B'more this weekend. I'm only a few miles away.
#45
Chris Driver, Chris French and Myself are the ones who got Grille Tech to make the grilles... so till you know the facts shut your fucking pie hole..... and the response you got from Grille tech is incorrect, I told you that.. so if you take it as me being angry then too bad...
#46
OWNED!
#50
Homeless
Frankly, we should be thanking Smitty for his persistence in this matter.
#51
Ricky: Drugs > Football
how do u install the upper grill, it didnt quite fit right so i put my gutter guard back on, i installed the lower gril and it looks tight, but i still have the uppper sitting in my garage.
#52
Originally posted by chris3240929
Also, there may be some adjusting to do still...95% right doesn't cut it for me.
#54
Homeless
I wasn't condoning that anything less than perfect is good enough for us. The pictures I sent back to Chris Driver indicating which areas I had to trim in order to get the top grille to fit. That's why I said 95%... because I think they still have some slight mods to make on their template. I will be interested to see if your findings are the same with the diamond style grille.
#55
Homeless
Originally posted by mrsteve
Did you remove the chrome "wings" in the upper grille or does the black just make it impossible to see?
#56
Where did you have problems with fitment(be specific so I know what to look for)?
#60
Homeless
Lemme send you the email I had sent to Chris Driver... it would best illustrate the process I used to fit the grille. PM me address if you get a chance.
#61
Dromaeosaurs/Velociraptor
I'm in for the upper and lower on my 01 CL-S. Can't wait to get this going. Since I just got in a wreck, I told the bodyshop to just toss the gutter guard, eventhough they offered to make another one to put in there. I want something with a lot better look and quality, which from the pictures I think I found it...cant wait!
#65
Homeless
Originally posted by BBsAcuraRacing
mine looks way better and it has been on for 3 years
There are two different types of grills being made, one with the round pattern, which you've seen, the other with a diamond pattern similar to what you have.
#67
Grille-Tech
Hi all, I am not a CL owner, but my buddy is ysr72champ who owns an '01 Sundance Gold CL-S. I drive a 2002 Maxima and just wanted to share some information that my fellow Maxima buddies have in regards to the Grille-Tech product. This looks really nice on the CL as it does on the Maxima, but what we have found is that after a time, the Grille-Tech products begin to rust especially if you are in an area that snows and the city uses salt on the roads. Typically the rust begins after a few months, but it is not apparent with all who use the Grille-Tech product. Just wanted to give you guys a bit of heads-up on this and hope that what I've mentioned doesn't apply here. Good luck.
-Tim
-Tim
#68
Homeless
Re: Grille-Tech
-Tim
-Tim
We have experience with their product, but from my own personal inspection, this new grill material is heavily coated.
#69
Grille tech writes as of 4/3/2004:
Smitty
I'm currently waiting for Chris French and Kevin Coakley to get back to me with info regarding the grilles. It's a waiting game at this point. It's tough when I have to rely on other people to fit and test the grilles, not to mention we didn't even make the templates. I think they need to be tweaked according to Kevin. I'll let you know what's going on when I find out more.
Thank You
Chris Driver
__________________________________________________
Looks like they are waiting for you guys to respond so we can get the show on the road..
Smitty
Thank You
Chris Driver
#73
Homeless
Smitty
Thank You
Chris Driver
Smitty
Thank You
Chris Driver
#74
Chris Driver has been really busy... I just got an email response from his as well so I guess things have settled down. I'm sending back the front grille that I fitted/cut early this week, and I'm also including my white outer grille trim piece for them to use as a template to check any new modifications to the pattern. The lower grille fits much better now that I saw how Mtbikr did his by angling it to fit the contour of the front lip. I also used 2 extra ties on the vertical pillars to pull the lower ends in more.
I had the same problem Chris3240929, especially with the lower grille. The white is too much of a contrast against the black material to show much detail.
Will keep everyone posted.
#75
Homeless
The only real trimming I had was on the right hand side...if you had it laying on the front, looking at the grill piece from the rear. Other than that, it was minimal trimming.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
