Great Video: Chasing an F40
Old 12-23-2002 | 04:55 PM
gavriil's Avatar
Moderator Alumnus
Apparently the car chasing it is an Elise. I am sure the Elise is heavily modified cos it aint that fast (although the F40 is clearly faster at the upper end). This is a nice video. Watch out for other Ferraris and Porsches.
http://www.bookatrack.com/g2/mikesto...OE[1].mpeg
Old 12-23-2002 | 09:25 PM
ruvz's Avatar
YOOOOOOOOOOOOOO!
Some nice driving!!
Old 12-23-2002 | 09:26 PM
GreenMonster's Avatar
Maybe the Elise has the Acura K20a engine ??
http://www.prototyperacing.com/k20kit.htm
240hp with a dry weight of about 1600 lbs (race prepped). Pretty good power to weight ratio
edit: made link clickable and added this:
http://www.randomresearch.com/dp/elise.htm
Old 12-23-2002 | 09:37 PM
NOVAwhiteTypeS's Avatar
OMG did u see where it said
"This is the Prototype Racing Lotus Exige, equipped with a 240 HP Honda K20A engine and 6 speed LSD trans. The additional 20 HP was obtained by re-mapping the ECU. Further development of the intake and exhaust systems, as well as more ECU work will result in even more HP without any internal engine modification."
so much potenital for the i-vtec 's I wanna see how well the 3.2ivtec will be after some ecu re-mapping
Old 12-23-2002 | 09:41 PM
btw this conversion was done by Prototype Racing
Old 12-23-2002 | 09:47 PM
gavriil's Avatar
Moderator Alumnus
Such a clean job that Honda engine sitting in the Elise. Nice info. Thanks.
Old 12-23-2002 | 09:49 PM
gavriil's Avatar
Moderator Alumnus
I think in order for an engine to get iVtec, it has to be DOHC. Ours is SOHC, so a complete revamp has to be done.
Old 12-24-2002 | 03:17 PM
Zapata's Avatar
Cost Drivers!!!!
That f40 just walks away from the lotus.
Old 12-24-2002 | 04:14 PM
wasn't talking about our current engine. I was talking IF honda produces the NEXT 3.2 as a i-vtec to use in the next CL/TL or NSX
Old 12-24-2002 | 04:37 PM
Zapata's Avatar
Cost Drivers!!!!
I don't think honda will stay with the 3.2 if it goes Ivtec. Since the CLS and TLS share the same drive train i would expect it to be the same.....unless Honda decides to break from its mold. Latest info for the TLS is a 3.4L v6 w/ 280hp.
Old 12-24-2002 | 04:47 PM
KavexTrax's Avatar
not bad for a Civic SI block eh?
Old 12-24-2002 | 05:09 PM
I first learned of the Elise K20A swap from a thread on the pelican parts porsche 911 forum. Someone was giving the 911 owner a hard time about being passed by the prototype racing Elise. Not really fair to compare a 240hp/1600lbs car to a 260hp/2430lbs car tho'.
To give credit where credit is due, you can find the original
Pelican Parts Technical Porsche 911 Technical Forum thread here
Old 12-24-2002 | 07:41 PM
gavriil's Avatar
Moderator Alumnus
331 HP per tonne for the Elise! Holy Moly!
2002 Lamborghini Murcielago= 348 HP per ton
2002 Pagani Zonda C12-S 7.3= 411 HP per ton
CLS= 162HP per tonne
Old 12-24-2002 | 09:27 PM
GOT PSI?'s Avatar
It's Go-Time.
Thanks for the vid - I luv that F40...kind of hairy, weaving in and out with those other high priced rides - especially in the corners...
TypeS860
09-03-2021 07:42 PM
Pham Alvan
03-16-2016 10:17 AM
gatrhumpy
19
12-31-2015 05:22 PM
eastsideride
10-15-2015 05:26 AM
Kres43
1G RDX (2007-2012)
10-03-2015 08:16 PM
