got te icebox from dean..will do install..
on sunday morning. any advice? i think my main issue would be removing the resonator. borrowed a floor jack. will attempt to use that without removing the bumper. advice would be appreciated!
East Coast Boost.!
taking out the resonater is easy, once you locate the bolts, just use a little finese, don't try and turn the bolts too much cause you will lose grip of them. The trick is lots of ratcheting. once that is done, should take you more than 30 mins to do the rest of the install, good luck.
something witty
LABEL THE HOSES. i got fuxored and it took my awhile it figure out which one goes where. do a search, i think there is a thread out there with pretty good instructions.
that fucking bitch resonator was a pain to remove. got the screws out but trying to get it out at the bottom took me longer than getting the screws out. did the install in about 2 hrs.
Nitin
09-30-2015 08:22 PM
03typeS6spd
01-13-2005 04:14 AM
NSX-Tuner
06-26-2004 11:12 AM
