Got my 01 CL S yesterday
Old 12-24-2011 | 08:36 AM
  #881
richardparker's Avatar
3.7L Nitrous Breathing CL
Glad to see you finally got your stuff in.
What kind of numbers are you expecting when your done adding parts and tuned ?
Are you staying N/A with it ?
Old 12-24-2011 | 08:44 AM
  #882
e30cabrio's Avatar
LFG RANGERS!!!!!!!!!!!
It is 99.999% done.
The tuner sent me this comparison between the old motor with quiet exhaust and now but it is one of the earlier runs before we got 302 TQ.
He said he is out of the shop until Wednesday and will email me the rest of the charts then.
The @#*! cutout wouldn't open. He thinks there are at least 15 hp & 20 lbs there.
grrrrrrrrrrrrr
I just fixed it. All I did was open the compartment it's wiring is under and look at it and it worked. I checked my wiring and nothing was loose. I re did it anyway.
It is 11.01 so even if I wanted to only low boost SC would be possible. I really want to be done.
Old 12-24-2011 | 12:49 PM
  #883
StreetKA's Avatar
ok how did you break it in so quickly so you went on the dyno already... sounds great and loud
Old 12-24-2011 | 01:01 PM
  #884
e30cabrio's Avatar
Broke it in on the dyno and then changed the oil. 7 miles on that change.
Old 12-24-2011 | 02:34 PM
  #885
StreetKA's Avatar
i thought it must be done like civicdrivr did... anyway WOOOOOT gratz man great project...
those numbers are without tune right ?
this car will be unbelievable loud when you open the cutout
Old 12-24-2011 | 04:13 PM
  #886
e30cabrio's Avatar
There are as many break in procedures & opinions as stars in the sky.
I am not a mechanic but the people that put the motor together and the tuner that has built lots of motors agreed it was acceptable to do it on the dyno.
He spent 20 minutes going through all rev ranges not staying at any rpm for long, letting it cool down until he said it was done. Then we changed the oil and he tuned it.
Old 12-24-2011 | 08:53 PM
  #887
civicdrivr's Avatar
Whats up with RDX owners?
There are all sorts of methods to breaking in a motor. The ultimate goal is getting the rings to seal properly. How you go about doing it doesnt matter.
BTW - I like the little loop-da-loop at ~2200rpms
Old 12-24-2011 | 08:57 PM
  #888
e30cabrio's Avatar
It's a happy rev!
Old 12-24-2011 | 09:18 PM
  #889
civicdrivr's Avatar
Old 12-25-2011 | 09:13 AM
  #890
e30cabrio's Avatar
Didn't Santa come yet?
Old 12-26-2011 | 06:32 PM
  #891
e30cabrio's Avatar
Got two new rear tires today.
Old 12-27-2011 | 05:10 PM
  #892
e30cabrio's Avatar
Got Fumoto?
Old 12-27-2011 | 08:17 PM
  #893
civicdrivr's Avatar
Go fumoto yourself, buddy.
Old 12-27-2011 | 09:08 PM
  #894
rush's Avatar
03 acura cl type s
Lol nice build
Old 12-27-2011 | 09:11 PM
  #895
civicdrivr's Avatar
We need to see real world, WOT runs on video so we can know this build was actually completed. For now, I do not believe you.
Old 12-27-2011 | 10:53 PM
  #896
StreetKA's Avatar
x2 on what (s)he said
Old 12-27-2011 | 11:56 PM
  #897
civicdrivr's Avatar
I see what you did there. At first, I 'd. But then I 'd.
Old 12-28-2011 | 04:24 PM
  #898
e30cabrio's Avatar
Uh oh, guess Civic's just too smart for me!
Fumoto U!
Old 12-28-2011 | 04:35 PM
  #899
I thought you were going to make more power with your build.
Alot more.
Don't you have all forged pieces stroked,head work,and cams ?
Old 12-28-2011 | 04:38 PM
  #900
e30cabrio's Avatar
Yes. I am missing about 18lb tq which I'll get back with the cutout open. These motors don't make much NA.
It is 60hp and 50lb tq over stock now.
Old 12-28-2011 | 04:44 PM
  #901
No plans to search out more pony's?
you did not go forged for no reason..
Old 12-28-2011 | 05:03 PM
  #902
e30cabrio's Avatar
I went forged to be bulletproof, improve cooling and be positive I would never have to think about the motor again. The issue with these engines is caused by bad rings/pistons.
Old 12-31-2011 | 07:29 PM
  #903
e30cabrio's Avatar
I just installed my modded clutch pedal. What a difference!
http://my350z.com/forum/engine-drive...tch-pedal.html
Well I've had my 07 Z for about a month now and seem to have nothing but issues with the clutch system. I've already pulled the transmission to replace the Clutch Slave Cylinder and adjusted the clutch pedal 4 times.
Basically I can't stand clutch grabbing at the top 1.5" of clutch travel when the pedal has to move 8" to the bottom.
The problem with the OEM design is the clutch pedal (when disconnected from the master cylinder) has a sprung rod that depending on its location in travel can spring the pedal upwards or down to the floor. This downward force makes it impossible to safely adjust the pedal any more then an inch or so downward. If you crank the master cylinder fork-to-pedal connector too far in you end up having the pedal's up position below the "neutral spring zone". This causes the pedal to be holding pressure on the clutch hydraulics, thus slightly removing clutch pressure plate force (AKA burn up your clutch).
The solution I found was to cut off the "linear spring rod" tab from the pedal arm and rotate-weld it a few degrees counter clock wise as seen in the picture. This increases the angular movement of the pedal from top to the neutral zone, thus allowing you to correctly adjust your pedal further down.
Old 01-06-2012 | 09:03 PM
  #904
StreetKA's Avatar
my buddy had same problem in G35
i still see no videos
Old 01-06-2012 | 09:17 PM
  #905
e30cabrio's Avatar
Post 880.
https://acurazine.com/forums/showpos...&postcount=880
Stroker installed and broken in on the dyno 2,000.00. 301 WHP/302WTQ
PRICELESS!!!!!!!!!!!!!!!!!!!!!
First drive after install
http://s20.photobucket.com/albums/b2...t=4823730f.mp4
http://s20.photobucket.com/albums/b2...t=deb85b06.mp4
Old 01-06-2012 | 11:17 PM
  #906
civicdrivr's Avatar
We want real acceleration videos. Not pulling out into traffic.
You are ignore until you address those requests.
Old 01-07-2012 | 06:50 AM
  #907
StreetKA's Avatar
^this
Old 01-07-2012 | 11:51 AM
  #908
e30cabrio's Avatar
Thanks for making it so easy to get you off my a*s!
Old 01-07-2012 | 11:52 AM
  #909
civicdrivr's Avatar
Old 01-07-2012 | 12:10 PM
  #910
e30cabrio's Avatar
Thought I was on ignore.
Fine, here's your F*cking video.
Old 01-07-2012 | 12:23 PM
  #911
civicdrivr's Avatar
Thats soccer. Title fail.
Old 01-07-2012 | 01:36 PM
  #912
e30cabrio's Avatar
AVI fail.
Old 01-07-2012 | 01:38 PM
  #913
civicdrivr's Avatar
Dont be jealous of my sick moves.
And you definitely dont want me to break out jazz hands.
Old 01-07-2012 | 04:47 PM
  #914
StreetKA's Avatar
AVI fail.
i thought it was ginger kid, wasn't ?
Old 01-07-2012 | 04:56 PM
  #915
e30cabrio's Avatar
I got yer jazz hands right here!
Old 01-07-2012 | 05:04 PM
  #916
civicdrivr's Avatar
Old 01-07-2012 | 07:50 PM
  #917
StreetKA's Avatar
Old 03-10-2012 | 08:38 AM
  #918
e30cabrio's Avatar
SUCCESS!!!!!!!!!!!!!
This is from an 07 W/O Brembo With TCS.
TCS/SLIP stayed on so I put a piece of electrical tape under the face.
Just verified SET flashes up when changing maps. I have three. full, valet and no start.
My car is officially fully optioned!!!!!!!!! (to my wish list)
Old 03-10-2012 | 02:00 PM
  #919
StreetKA's Avatar
a real videos ? how it pulls ? i do not really follow of what you posted today
Old 03-10-2012 | 02:24 PM
  #920
e30cabrio's Avatar
I really have no safe way to take moving videos. Base Zs don't have cruise. Mine now does.
First it had it but no dash lights, Nissan omitted the .2 cent leds on base clusters that go to options the car does not have.
