Got Ingalls Ball joint and camber kit installed. PLEASE HELP
I need FI
okay, after fixing my problem with my headers, I am confronted with another. I got my camber kit in the rear installed and balljoints in the front. Everything was from ingalls. Apparently its very high quality stuff.
Anyways, the tune shop says they did the install correctly, but everytime I hit a slight hole or bump, I here a loud "TOCK!" from the front right side..
Any ideas what could make that sound? And again, the sound wasnt there before installing the balljoints.......
All suggestions are appreciated!!
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Adventurist.
The ball is not inside the joint. You better return it and get it sixed before it completely pops out. Do you know if they used a standard pickle-fork to install?
I need FI
the adjustable ball joint camber kit sucks from my experience. they will loosen up over time and move around in the control arm. mine rattled on bumps cuz it was loose and threw the alignment all off. i've since got the ingalls adjustable control arm camber kit. in my opinion, thats the way to go for our cars.
I need FI
Originally Posted by berny
the adjustable control arms are on the rear... i don't think there are adjustable control arms for the front
http://www.ingallseng.com/parts/39201-39204.htm
Because you are dropped 2inches (according to your sig), the upper control arm could be hitting the top of the fender well. That is what happened to me, which forced me to raise my car up a little bit. I do have a first gen however, so it could be a little different. I also was not using a ball joint camber kit, and dont know a whole about them, but it is at least worth a shot to make sure this isnt what is happening. Hope you get the problem fixed!
I need FI
yeah they have them for the front....i have them on my car. i also have the adjustable rear control arms.
I doubt I'm hitting the fender, but thanks for bringing that up...
I need more suggestions in case the tuner shop doesnt fix the problem
I need FI
i know that now, i'm not using a control arm because of the limited space. I don't want to hit the fender. Why, would you say it would be better to have a control arm than a ball joint? I was told that a camber kit with control arms in the rear and camber kit with ball joints in the front was the way to go...
am i wrong?
am i wrong?
I need FI
okay, the tune shop called me up. they said the ball joint was touching my fender (DAMN good thing I didnt go for the control arm instead)... so that problem is fixed... i'm at school now, but will try it out later on to see if everything is cool
am i wrong?
am i wrong?
![Huh](https://acurazine.com/forums/images/smilies/huh.gif)
Its the exact opposite. The ingalls control arm is designed to clear the fender. The plain ball-joint camber kit is larger and may cause problems like hitting the fender, which you are experiencing.
It's not that big of a deal. I have tein ss dropped 2" also. The real problem is before the top of the cotrol arm was flat. Now the slider is a 1/8" the nut is 1/2" and the bolt sticks out the top about a 1/2". You just added an 1" or more to the top of your control arm. On certain bumps the top of the bolt slams into the bottom of the shock tower. If you look in your engine compartment you might see slight dimples. Like something was trying to punch through from the other side. Plus if you jack up the car you would see the scratches from the bolt also. I have the same problem. I just try to avoid bumps and potholes better. I have never had a problem of them coming loose or anything and I corner like a maniac and I adjust the camber twice a year when I go from my winter setup to summer and back. I torque the bolt to 75lbs when I adjust. Now that they do make a control arm I will probably be switching see I'm getting tired of swerving around bumps and holes due to the worry.
i meant : I CANT have the control arm.. sorry for the mistake above
I need FI
bottom line though is that the tune shop took the ball joints off and put them back on, now nothing is hitting or rubbing, i'm good to go
emailnatec
29
09-28-2018 04:27 PM
lanechanger
10-13-2015 10:56 AM
