Going to change the timing belt on the CL-S. What parts do I need?
Old 02-08-2007, 06:47 PM
DRM600's Avatar
So far I've gathered that I'll need to replace the:
1. timing belt (I'll need two right?)
2. water pump
3. tensioner pulley
4. coolant
What else do I need?
Old 02-08-2007, 06:54 PM
anthracitecl's Avatar
maybe cam seal, crank seal.
Old 02-09-2007, 03:11 AM
Blown is Best
Allout's Avatar
I'd probably do the thermostat at the same time and all the belts too.
Old 02-09-2007, 05:20 AM
I'm a Vagiterian.
All Mine's Avatar
According to THIS THREAD here's what you'll need. I'd suggest reading the thread, as well.
$96.60- New water pump.
$29.44- Timing belt.
$53.20- Tensioner pulley.
$43.63- Idler pulley.
$11.94- Alternator belt.
$10.99- Power steering belt.
$12.60- Power steering fluid.
$21.75- Spark plugs. NGK PZFR6E-11
$280.70- Total
I'd also suggest getting a supercharger, too.
Old 02-09-2007, 12:56 PM
Sloth32's Avatar
I did mine about a year ago and I found out you need a special tool to get the crank shaft pulley off. I couldn't get around it. You may be able to borrow one or rent one. i couldn't
Old 02-09-2007, 11:03 PM
o1s
o1s's Avatar
that is the one thing that i made the dealership do. only because i was lazy.
Old 02-12-2007, 09:34 AM
fender4's Avatar
don't forget to check your motor mounts,, now is the time to change them if bad,,
mada51589
05-03-2022 08:54 PM
02-25-2020 09:57 AM
2012wagon
09-29-2015 04:21 PM
asahrts
09-04-2015 05:55 PM
Quick Reply: Going to change the timing belt on the CL-S. What parts do I need?
