Gauge Cluster LED/Dome Light upgrades ?
Has anyone done the LED upgrade Conversion on the Gauge Cluster and Odometer Wedge.
I see they how have Dome and map LED upgrades, i wonder how hyper white would look.
http://www.ledautomotive.com/OrderIn...03TL/index.asp
i've done an led upgrade and if you did a search you would've found my thread. http://www.acura-cl.com/forums/showthread.php?t=172196
i have since redone my gauges with the ledautomotive leds (blue ones not hyperwhite) and also fixed my climate control screen. however, i'm not that happy with the gauges because the blue doesn't really match the other blue on my clock and climate control. i bought some really bright 8mm led's from ebay but i haven't had the time to install them behind the gauges yet. if you use hyperwhite led's for your gauges, they'll come out light blue when lit up. i tried doing my odometer with 3mm pure white led's when i was working on my gauges but they wouldnt light up and i couldn't figure out why until a few weeks ago when i found out that the bulbs behind the odometer are 9.5v. so that would mean that i'd have to use 330 ohm resistors instead of the 470 i was using for everything else. if you have any other questions, PM me...i'd be glad to help.
rockyboy
01-25-2016 06:00 PM
sockr1
10-01-2015 01:31 AM
brandnewcolony
09-12-2015 10:39 AM
