Fuel Injectors??
You can get bigger injectors but why, with your mods you certainly don't need them?? It will just cause your car to run with the FT in the negative. But if you really want to contact RC Engineering, they can get you what you want.
http://www.rceng.com/
Anyway, I beleive ours are about 320 cc/min.
I WANT TO RUN A 75 SHOT, AND I DONT WANT TO RUN LEAN, SO I WAS EITHER GOING T0 GET LARGER INJECTORS OR A LARGER FUEL PUMP. UNLESS U KNOW ANOTHER WAY SO I DON'T HURT THE MOTOR
But even when you are running nitrous, the pulse width remains unchanged. So by going with larger injectors you would get more fuel when on the bottle, but then also at cruise and idle. This will in turn cause the FT values to go negative which will shorten your pulse width. Then you will be back at the start, getting basically the same amount of fuel as with the stock injectors.
When you are on the bottle, depending on the system used (wet or dry) you use more fuel by additional flow through wet nozzles or increased pressure through the stock injectors. In either case you are pushing the limits of the fuel pump. So if you want to be sure that you have enough fuel, look at replacing the fuel pump and leave the injectors alone.
get yourself an HKS ignition, denso iridiums, & lose your cat... check my sig.
make sure you replace your denso plugs after going through every bottle or two...
you'll be alright. i was running 100 shot w/out a problem...
just don't show up around your dealer!
joflewbyu2
08-18-2019 10:38 PM
ExcelerateRep
10-14-2015 08:20 AM
joflewbyu2
10-08-2015 11:16 AM
