Fog lights
Chamorro
Any auto parts store will carry aftermarket PIAA bulbs that will be brighter and look better in the housing for our parking lights (fog lamps). I went with these, they work great and are pretty cheap:
http://cgi.ebay.com/Car-White-9-LED-...item3cad3dbf4d
Not that exact buyer, but if you hunt around you can pick up a pair for like 10 bucks or so. If you want a good set, maybe 20. I got mine from a former member and love them! Match HID color and are bright!
Chamorro
No problem, and place like www.vled.com or www.superbrightled.com has warranties on their stuff but its a little more pricey. vled is def a good place, good people and quick service!
Chamorro
Part #
33901-S3M-A02
About halfway down the page in the middle you'll see ' LIGHT UNIT, R. ACCESSORY
Just go to your acura/honda dealer and give them the part number or have them look it up. They should pricematch the part for ya. My dealer did!
Hey Dave586270 Have you tried the LED lights instead of the HID fogs they actually look really good. I had to put in blue ones because thats all they had but when they get the white ones in i am going to switch to them. I will take a picture tonight and upload it so you can see how they look.
Moderator Alumnus
OP, the fog lights on our cars aren't really called fog lights. They are running lamps. They do absolutely nothing but show more light on the car and are not true fog lights. I took them off my car and just had the '03 inserts put in. It looked a hell of a lot better IMO.
"DD" Designated Drinker
u can make an h serires bulb fit but i learned u have to cut holes in ut housing or it will burn and melt shit! lucky i caught it right before they melted down!
LED's are the way to go
Noobalicious
What part(s) were melting just the harness or other structural part(s) of the Lamp housing?
from the looks of it when i took it apart it was just the housing above the bulb, so i took a dremil and cut away some of the material and now no problems.. i did notice water in there after a touch free car wash so i drilled a small 1/8" hole in the bottom corner. then no water problems
ya so I tried installing HID and they melted the shit out of the housing in 3minutes....will using 3000k instead of 6000k make things work you guys think, or should i just go with LED's.....?
Also what Bulb fits in the housing? its not a H3 is it????
Whats up with RDX owners?
What fogs are you running?
No I mean the projectors themselves.
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
