Flashers (turnsignal) problem
Old Jan 29, 2009 | 10:15 PM
CivicB18B1's Avatar
hi there, since the last week my turn signal started to blinking fast (the right only).
When i checked outside, the rear right was blinking fast and the front right does not flash.
left is fine and no problem.
What could be the problem?
Old Jan 29, 2009 | 10:40 PM
civicdrivr's Avatar
Your right front bulb is the problem.
They blink fast when a bulb is blown.
Old Jan 30, 2009 | 10:26 AM
fuzzy02CLS's Avatar
Yes bad bulbs. Word of advice, replace them in pairs.
Old Jan 30, 2009 | 10:37 AM
SG81's Avatar
Missing My CL-S
change the bad bulb and you'll be fine
Old Jan 30, 2009 | 10:42 AM
CL-Slick's Avatar
Chillin' in my trailer
Yeah, new bulbs.
Old Jan 30, 2009 | 11:37 AM
thevikas87's Avatar
Your mom is in
ok so, my bulb for the turn signal is on with the headlights...but when i go to take a turn and use it, its does NOT blink, and the rear tailight blinks really fast...i changed bulbs all over...what could be the problem? Like how the hell can it light up and stay on, but not blink?
Old Jan 30, 2009 | 01:46 PM
gaping46and2's Avatar
SOLD: 03 SSM CLS Auto
The 1157 turn signal bulbs are dual filament. It's possible that one filament may burn out and the other doesn't. Replace the bulb.
Old Jan 30, 2009 | 03:18 PM
thevikas87's Avatar
Your mom is in
ok, so i went back out and tried again, NEW BULBS, same result, BUT one new thing, i noticed, if i have the turn signal on, and i move the wiring that the bulb is on the end of, like just move it around, it starts flashing normally...i guess its just a loose connection?
Old Jan 30, 2009 | 03:21 PM
SG81's Avatar
Missing My CL-S
sounds like a loose wire
Old Jan 30, 2009 | 04:04 PM
thevikas87's Avatar
Your mom is in
well my question is, how the hell is the bulb on with the headlights, but it cant blink? but yes there does seem to be some sort of loose wire...
Old Jan 30, 2009 | 04:38 PM
Old Jan 30, 2009 | 10:40 PM
AnthraciteBeast's Avatar
Yea or you might need a new socket. Although im not sure if the socket on these cars can be replaced since ive never looked at it
Old Jan 31, 2009 | 08:19 AM
I forgot, try replacing your flasher
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
