finally got my IM in to start porting, and 80mm TB..."?"s about TB!!
Old Aug 17, 2012 | 11:20 AM
  #41
reese8789's Avatar
Originally Posted by 03CLSMT
The TB i purchased wasnt the best, ebay 100 bucks... its not worth the hassle to put all custom mounts on... Im thinking about ditching it and just buying
this...
http://www.ebay.com/itm/BLOX-76MM-TH...b70afc&vxp=mtr
Atleast the TPS wouldnt be a problem and map sensor holes are made like stock.
Let me know what you guys think
This is the way to go, by far the the most hassle free option for a larger throttle body. Im running the 74mm blox throttle body. Also they come 1mm bigger on the inlet side so if you get a 76mm it will have a 77mm opening but tapers to 76mm at the butterfly.
Old Aug 17, 2012 | 12:31 PM
  #42
03CLSMT's Avatar
well i just ordered the 76mm. What kind of customization if any is needed to get this sucker running.
Old Aug 17, 2012 | 12:55 PM
  #43
AnthraciteTypeS's Avatar
6mt swapped..smart
6mm is debatable (talking bolt on tb's- no customizing needed). Mine was $125 shipped. The 76mm blox was $250. I couldn't see spending double for 6mm. I'll upgrade down the road if I really feel the need
OP- I think you made the right move. As I said earlier, IMO not worth the hassle for an 80mm, but to each their own
Old Aug 17, 2012 | 12:57 PM
  #44
gnuts's Avatar
3.5 psi
+1 For More Info On Customizing.
Old Aug 23, 2012 | 01:10 PM
  #45
03CLSMT's Avatar
I just got mine in yesterday... there is no customization needed except for the IACV...you will need to take it off make a custom plate and bracket it somewhere for it.
Old Aug 23, 2012 | 02:38 PM
  #46
gnuts's Avatar
3.5 psi
Post Some Pics When yours Is Done
Old Aug 24, 2012 | 10:22 AM
  #47
03CLSMT's Avatar
its done, Im just running it without the IACV working... it has to be plugged in or it will run in limp mode...but you can just plug it in, it will run fine but the car idles way too high. Personally i miss my CL so much i dont mind it right now...Ill make a block off plate this weekend.
I can try to take some pics later and post
EDIT: I REALLY wish I would have known the b series was a direct bolt on to the j series IM. I would have saved a lot of time.
Old Aug 24, 2012 | 02:38 PM
  #48
6mt swapped..smart
Pics and more importantly, how's it feel? Didn't you also port the upper manifold too?
Old Aug 24, 2012 | 02:40 PM
  #49
gnuts's Avatar
3.5 psi
Notice Any Difference? I'd like Too See Details On How You Get The Iac To Work In The End.
Old Aug 24, 2012 | 04:21 PM
  #50
03CLSMT's Avatar
alright ill do a write up on how i did my IAC once i figure out which route im going to go with it.
Yes i did port&polish the IM and removed the butterflies and added p2r gaskets
as far as how the car feels..
Throttle response defiantly improved
Power seems to vastly improve above 3.5k (not sure exactly bc I haven't dynod and don't plan on it until i find a good piggyback or something nice to tune w that wont be overridden by the ecu)
Ill try to get pics up soon but kinda have a busy weekend
Old Aug 29, 2012 | 10:40 AM
  #51
03CLSMT's Avatar
Okay so I made a thin block off valve out of a piece of aluminum and it defiantly fixed the idle problem but with JUST A BLOCK OFF and no vacuum hoses connected VTEC no longer engages... not sure why this is and not sure if people even realize this because I've done some reading on the block off valve and no one (that ive seen) makes mention of VTEC no longer working. Well It doesn't.
For future reference i want people to know you have to make more than just a block off plate for the IACV
Old Aug 29, 2012 | 12:24 PM
  #52
civicdrivr's Avatar
Check your oil level.
I had my IACV blocked off for about a year, VTEC always worked.
Old Aug 29, 2012 | 03:04 PM
  #53
03CLSMT's Avatar
ahh Thanks Civic, I didnt even think about that, the cars never burned oil but now that you mention it, I did think it smelled a bit like that yesterday. I'll get back to you guys asap and let you know the verdict.
Old Aug 30, 2012 | 11:34 AM
  #54
03CLSMT's Avatar
nope oil level was fine. the car wont rev past 5.5 or 6k it cuts out. Im thinking the car may have been running rich while i was trying to get it working properly and clogged the primary 02 sensor... what else would cause the car to cut out at 5-6k
Old Aug 30, 2012 | 11:46 AM
  #55
Catfisha's Avatar
Giant Blue Car
It just spontaneously dies?!
Old Aug 30, 2012 | 12:26 PM
  #56
03CLSMT's Avatar
no it runs fine if you wouldnt even notice it if you didnt rev past 5.5k it just hits a rev limiter
Old Aug 30, 2012 | 03:45 PM
  #57
6mt swapped..smart
Any codes? Check your tps, I think it may have gone out of spec and you need to recalibrate it to .5v with the throttle closed. I had this problem just earlier this week with the car cutting out at that rpm, but it threw a code. You may need to notch the tps holes to get it to the desired voltage
  #58
6mt swapped..smart
Old Aug 30, 2012 | 03:48 PM
  #59
Catfisha's Avatar
Giant Blue Car
Maybe too much play in the throttle linkage?
Old Aug 31, 2012 | 11:06 AM
  #60
03CLSMT's Avatar
Ha thats crazy i was about to post what the problem was I just fixed it last night and it was exactly this! now my car runs fine finally! idles ~800rpm and VTEC works/ pulls all the way to redline. too bad i was a day short for the local meet.
CATFIShA come to the next wed meet...need some more CL/TLs
Old Aug 31, 2012 | 11:14 AM
  #61
Catfisha's Avatar
Giant Blue Car
I'm so happy it's not idling at 2,000 anymore!!! I'll be there next Wednesday!!! What does you car look like by the way? Post its picture!!
Old Sep 1, 2012 | 05:32 PM
  #62
03CLSMT's Avatar
my cameras lost somewhere around here
but its a NBP stock exterior, except painted stock rims bronze...and its kinda loud ... theres not any second gen CLs at the meet just TLs and some TSXs
note: hope to find something to tune with now bc i want to dyno... car pulls really hard after ecu had some time to adjust
Old Sep 2, 2012 | 12:36 PM
  #63
Cocoa's Avatar
2600lb CL
this...
Is this 76mm TB a direct bolt on without ANY problems or modifications with the IACV, TPS, Map Sensor, etc?
I've been out of the game for some years and it seems I've missed out on a lot of new info I'm coming across all the j-series sites.
Old Sep 2, 2012 | 02:56 PM
  #64
civicdrivr's Avatar
Holy shit, Cocoa!!
You still have the 1G?
Old Sep 2, 2012 | 03:04 PM
  #65
03CLSMT's Avatar
its all direct bolt on, except the IACV it doesnt have a mount for it, but its really easy to just take it off your stock tb and make a block off plate for it.
I just used a thin piece of aluminum and bolted it down with some liquid gasket. Car runs fine. its a 100 degrees out and the car still pulls hard! Cant wait for it to cool off here in Dallas/ft worth area.
Old Sep 2, 2012 | 03:37 PM
  #66
03CLSMT's Avatar
well now I have my stock TB minus the sensors for sale, and a stock intake manifold and p2r TB spacer. PM for info if interested
Old Sep 2, 2012 | 09:06 PM
  #67
Catfisha's Avatar
Giant Blue Car
AWWWW...well, I'll be out there next Wednesday so you won't alone...but my pretty little car isn't as powerful as yours....
Old Sep 3, 2012 | 01:12 AM
  #68
rush's Avatar
03 acura cl type s
I have a manifold that's already cut if you want ?? That way you can take your time & a back up.
Old Sep 3, 2012 | 02:32 PM
  #69
03CLSMT's Avatar
huh? I was saying i have my old stock IM and TB for sale now since i got my ported IM and new TB on and working
Old Sep 3, 2012 | 08:51 PM
  #70
gnuts's Avatar
3.5 psi
Find That Camera!
Old Sep 3, 2012 | 08:58 PM
  #71
civicdrivr's Avatar
Phones have cameras too
Old Sep 3, 2012 | 09:05 PM
  #72
gnuts's Avatar
3.5 psi
Maybe He's Rocking The Zack Morris Phone
Old Sep 3, 2012 | 09:31 PM
  #73
civicdrivr's Avatar
Crisis averted
Old Sep 5, 2012 | 12:33 PM
  #74
Catfisha's Avatar
Giant Blue Car
I already have the battery for my camera charging....a picture will be taken...
Old Sep 5, 2012 | 01:06 PM
  #75
03CLSMT's Avatar
Catfisha ... I dont know if your going to the meet tonight but i might be a little late.
Not sure if u knew but im a HUGE cowboys fan, tonight is opening kick off against the giants ...so I'll be a tad late 10-1030 it ends around 12-1230
Old Sep 5, 2012 | 01:16 PM
  #76
civicdrivr's Avatar
Ill be watching the Giants beat up on the Cowgirls
Old Sep 5, 2012 | 01:27 PM
  #77
Catfisha's Avatar
Giant Blue Car
Oh man.....I guess I should bring a pillow and blankey....
Old Sep 5, 2012 | 01:36 PM
  #78
gnuts's Avatar
3.5 psi
I might Do This Mod Next. Would It Still Be Beneficial If I'm Supercharged?
Old Sep 5, 2012 | 02:09 PM
  #79
03CLSMT's Avatar
yesir
Civic - if romo can get any sort of time hes going to pick apart that defense = )
oh and if anyone's curious my MPG has noticeably dropped ... ill do the math on my next fill up
Old Sep 5, 2012 | 02:33 PM
  #80
civicdrivr's Avatar
More air = more fuel
Romo doesnt have the balls to pick apart that defense. But it doesnt matter. Its only the first week. Even if they go 6-0, surely they'll choke by Thanksgiving
