Finally, drilled out these screws...
qwpobird (10-15-2012)
The following 2 users liked this post by HEAVY_RL:
civicdrivr (10-17-2012),
only this one got me headache
(the above four pics are just different angles of one single screw ha)
lowrd on tein CS biatch
i think most people think u can just twist them off when really u NEED the right 3# star bit and a drill which will snap the screw loose.
yes they are impossible to move if u try to get them out conventionally but if u just let tools be tools. they fly off..
the only way u would have to drill them is if someone before fucked them up badly.. cause i got one screw that's pretty twisted per se and it still has no problems.
a drill is your best friend for this task. that way u can just lean all ur weight on the drill and then let it do the twisting. this is is why it works and even using the right screw head bit in a socket with more leverage power still wont do the job
Whats up with RDX owners?
I didnt have a bit small enough to fuck them the way you did.
97BlackAckCL (10-19-2012)
I had to drill mine out and it was a giant pita........did not replace them.
civicdrivr (10-19-2012)
Learning New Ways!
Had to drill all of mine out. Really does not take long if you are prepared to do so ahead of time.
That being said, its not unusual to see them replaced at a dealer or service center.
1 rotor i had 1 screw come out easily. The other 3 either needed to be drilled or snapped off in the process. I havent had them in in over 500k miles
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
