exhaust pipe diameter per engine size/hp
#41
found the 63mm(2.5") inlet Greddy Evo2 muffler off of an is300 locally and i can pick it up for $70!!!!
will be doing that on friday unless something crazy happens
#42
i agree with you, and that was my first choice like i had said on another post, but since i saw you were going to do that, i decided on either the Greddy evo2 or a Spoon Itb N1. The spoon looks cooler, but only sound clip i found was on a fit and s2k.
i was told only turbo applications use 3" by numerous guys, and power would be lost if you ran that on an Na car with 300hp. Now if we had 4-500 hp NA, then 3-3.5" would be good for single.
I think the 2.75" you were wanting to do will be good, im only doing 2.5", but i have no mid-muffler, and plus i plan on a h.f.c. and 2.5" collector on my header in the future...
gl
gl
You have to keep in mind that setup is for maximum hp at the top end tho. For a street car, without all the engine work, I would think 2.5 is better. Plus for 3" you would need the custom headers like p2r had.
#43
like I have said before, p2r used a single 3" exhaust on their time attack accord, they were 3.2 liter N/A and that is the best dyno I have seen for this engine for being both n/a and only 3.2 liters.
I was thinking the exact same thing...thanks man
#44
so i got my exhaust done today and it sounds very good and mellow, even without the resonator. so it is straight 2.5" into a greddy evoII 2.5" inlet off of a is300...
the guys didnt angle it like i told them, they made it flush and straight as it would be if i had duals, so i think it looks like shit...
performance wise, it feels like i may have a bit more torque than i did before but less when vtec hits...dunno, think i may have went too small and should have got the 3" and just added a resonator so it wouldnt be too loud, but that greddy muffles the crap outta the sound, so i may not have needed a resonator...
so in conclusion, the 2.5" isnt bad, but it makes me think i wanna do 3" instead..will have clips up when i go to the track next saturday...
#46
Dyno next week for sure to see what im putting down...
#52
No you don't.
2.5 is good for 250-275 whp. Unless you are pumping out over 350whp you wouldn't need a 3" exhaust.
http://www.autolounge.net/calculator...ustsizing.html
#53
Whats up with RDX owners?
3" is overkill on my stroked motor. I may gain a few hp up top but the torque loss will suck, and how much time per day do you spend at high rpms? Theres no reason you need it on a relatively stock 3.2l. Its either 1) all in your head or 2) you just need a well engineered, quality exhaust.
Ive been meaning to ask, since you are going through exhaust setups pretty quickly, what type of bends are you using (dont say crush bends, please dont say crush bends)?
Also, have you reset the ECU or at least let it relearn?
#54
look, as i stated many flippin times, the torque on my current exhaust is higher. So in town, this exhaust is probably near perfect for driving casually around town...But, since i am tracking this car every couple months, then its not perfect because my top end has suffered. This is the 5th or 6th exhaust ive had on 2 cars, so i think i know what im talking about.
Im 31 years old, AND im not Jacob and run my damn mouth on here without experience, so please give me your opinion, but dont act like im a f'n idiot...
this conversation is obviously going the wrong way, so ill just end it....thanks 4 your input guys...
#55
Once again, crush bend piping or mandrel? What cat are you running?
#57
Mandrel from the cat to the axle, then i believe it looks like crush bend at the muffler...
stock cat.
I am gonna do a hfc and possibly 2.5" collector on the headers, so it is a true 2.5" all the way back, which will be probably much better...
Sorry for going off earlier, i just get pissed on here sometimes because there are some real idiots on here, and i dont consider my self as one, and i feel some people thats been on here just as long as me try to talk down to me...
So, looks like i am gonna try this route^^^^ before i jump the gun on the 3".
stock cat.
#58
I think if you went 3" it would just get worse. I would assume your exhaust is bottlenecked at the header collectors and cat, that is probably why you aren't happy with the power.
#59
Yea, your exhaust is 2.5" at the collector to a 2.25" cat to 2.5" from there to a 2.36" muffler (it was a pain in the ass to find, but the Greddy EvoII is300 muffler is 60mm). There are some definite bottlenecks there.
#60
#61
Well, it looks like the 75mm HKS Carbon-Ti won't be on my car either. I originally ordered it almost 45 days ago. They finally said that they can't continue with the order at the price they sold it to me for and can either give me a refund or charge me an extra $150 to make up for the difference. So, I'll be getting a refund and looking to probably just get the regular Ti or the APEXi N1 in 75mm. I'm going to order another header and chop it up to have 3-1 w/ 2.5" collectors and then 2-1 3" collector with a hi flow 3" cat and a vibrant 14"x3" resonator. If it works, then great... If I'm not happy with it, it will end up on the black market for sure. lol
Basically:
HKS Titanium Muffler 75mm (60mm pictured)
Vibrant 1142 3" Ultra Quiet Resonator
Vibrant 46566 3"x6" Flex pipe (for the header)
Vibrant 7039 3" in/out Ceramic Core Hi Flow Catalytic Converter
(I was looking at their Full Metal race for higher flow, but can cause CEL)
and plenty of Vibrant piping:
2x 3"x5' straights
3x 2.5" every bend (1x45° & 1x180°) to custom fab the header
I was going to do the 2.5" like yours(aaron's) but have my friend that has his own Meineke weld it up for cheap. But after looking at everything. I just think I would like to try the full true 3" and see what happens. I've been going back and for far too long on it really.
I may order some of Vibrant's 4" stainless bends and do a gradual decrease to 3" to make a custom intake as well. (not likely though)
Basically:
2x 3"x5' straights
#62
I guess my research and measurements were wrong on the muffler inlet. The piping that was on it was 60mm, but im 99% sure once that was cut off, the inlet on the muffler itself was 2.5"...dunno, but if so(60mm), it will be replaced later
So, do you agree with me on my future plans with the exhaust then? meaning hfc and such?
#63
Absolutely. The stock cat wouldve been ditched at the same time as the rest of the exhaust if I were you.
AARONSredTYPE-S (07-12-2011)
#64
it was debateable to me until ive been driving the car.
I found a 2.5" inlet/outlet cat(not test pipe) i was gonna get a while back, i was just worried about throwing a code...hondas are funny about those things, but i will give it a try...and you think the b-pipe or header collector if you will, is 2.5" already? if so, then the only things are a new cat and bigger inlet muffler(maybe)...
thanks for your opinion and advice...
#65
Basically:
2x 3"x5' straights
Basically:
2x 3"x5' straights
#67
#68
i had power gains up top with my last exhaust that i just replaced, which had a single 2.5" inlet, dual 2.5" outlet muffler...
#69
Ultra Negro
I still think on a street daily driven car with just bolt ons so to speak a catback exhaust is just fine, I mean aren't these catbacks tested before they are just casted up?, Why not just buy an electric cutout? that will totally solve your exhaust problem right there.
#71
Somehow, vibrant figured out how to make a extremely good resonator in a smaller package. They nbake the longer, more narrow ones, but this one works better. My buddy is running it on his supra and swears by it. Lol
AARONSredTYPE-S (07-13-2011)
#72
The pipe that has the flex on it where both manifolds meet and go to the cat, is what im talking about...it hasnt been modified. it is the original xs power full set-up to a stock cat, then my 2.5" exhaust pipe to the greddy muffler...
#74
Why did you get another CL?
#75
I kinda like the idea of the electric cut out for your track days. Provided there is not noise restrictions at the track you run.
#78
yeah, that wasnt a bad idea with the cutouts, and there is def no restriction in any way at the track near me...
You are also probably correct on that cheap cat i found, and i will do more research. i just didnt wanna spend 300-350 on a damn cat from xlr8, but may have to if everything else is gonna throw a code...florida doesnt have emissions checks at all, but i dont like driving around with that damn light on and it probably would throw other things off as well because of the ecu trying to compensate...thanks man
Anyone know the length of our stock cat.?
#79
Just get a universal Magnaflow.
#80
