engaged clutch and nothing...need some bay area help
Old Nov 4, 2010 | 11:21 PM
Elijah J's Avatar
Exclamation engaged clutch and nothing...need some bay area help
at 150,000 I think its toast. I drove it to the store and it drove like normal but when I came back to it I couldnt get it do anything but rev. I cant think of anything but clutch. Anyone know anything else or any test that can be done to confirm? Also, I just moved to Santa Cruz and dont have a mechanic out here yet, I know theres a huge AZine presence in the bay, who knows a good mechanic in bay area (preferably as close as possible to santa cruz)?
THANK YOU SO MUCH FOR ANY HELP
Old Nov 5, 2010 | 05:13 AM
StreetKA's Avatar
Snapped axle ? I dont think clutch would give up like that ?
Old Nov 5, 2010 | 09:05 AM
CobraSpdRH's Avatar
You check the linkage? It could be as simple as it not engaging, I had that happen on my old Integra once.
Old Nov 5, 2010 | 09:13 AM
black label's Avatar
Trolling Canuckistan
Clutch fluid? When I had my 5th gen Prelude (which also had about 150K on it at the time, I drove to work one day no issues but when I went to leave I had issues getting the car in gear. I would push the clutch in but there was still resistance when trying to put the car in gear. Turns out a had a very minor leak in the clutch master cylinder and I didn't have enough fluid to make the system work. Had to bleed it and refill, took care of the issue.
Old Nov 5, 2010 | 09:36 AM
phee's Avatar
I got the Shifts
sounds like a broken axle. will it go into gear?
Old Nov 5, 2010 | 09:58 AM
Elijah J's Avatar
Yea it goes into gear but doesnt move at all.
Old Nov 5, 2010 | 10:14 AM
Elijah J's Avatar
It seemed odd to me too. Is that something I can slide under the car and see? I've never broke an axle before so I dont know what to look for. Is that more or less expensive than a clutch?
Zero resistance in putting it in to gear ... Ahhhhh the prelude. I had a 95 that I dumbed way to much money into - memories.
Thanks to al who chimed in.
Old Nov 5, 2010 | 12:23 PM
fuzzy02CLS's Avatar
A good clutch test is to put in gear then release the clutch. If it lunches & stalls, the clutch should be ok.
Get a friend or 2 & try pushing the car & see if you hear any noises, like grinding, clicking or popping.
Old Nov 5, 2010 | 09:17 PM
Elijah J's Avatar
Turned out to be an axel. It rusted all the way through. Mechanic said in his 35 years he'd never seen such a thing on a newish car. Anyway, all fixed. Thanks to those who spoke up!
Old Nov 5, 2010 | 10:30 PM
CH46ESeaKnight's Avatar
WOW! That's effin crazy!
Old Nov 6, 2010 | 05:44 AM
StreetKA's Avatar
Told ya
Old Nov 6, 2010 | 06:00 AM
RooEng's Avatar
I thought 6mt's have a LSD. Wouldn't the car still move by turning the other axle?
Old Nov 6, 2010 | 06:07 AM
StreetKA's Avatar
Its limited slip differential not axle lockup.
Old Nov 6, 2010 | 08:22 AM
phee's Avatar
I got the Shifts
yea. the LSD needs both axles to cause resistance and roll
Old Nov 6, 2010 | 03:12 PM
civicdrivr's Avatar
Youre not the first to snap an axle at that exact spot.
Because of the dampener, water and dirt gets underneath it and keeps eating away at it. If your new axles have the dampeners as well, run a bead of silicone around the seams and let the silicone dry for about 24hrs before you drive on it.
Old Nov 6, 2010 | 04:25 PM
Elijah J's Avatar
Silicone...good idea but its already done and driven. Any point in applying it now?
Elijah J's Avatar
Told ya
Old Nov 6, 2010 | 04:46 PM
phee's Avatar
I got the Shifts
you can still apply it. just have to let the car sit for 24
SidhuSaaB
May 30, 2020 12:40 AM
knight rider
Mar 4, 2016 08:59 AM
JDM96specCTR
Oct 17, 2015 01:06 PM
Avenger411
Oct 11, 2015 03:53 PM
rangomango
California
Sep 24, 2015 05:47 PM
