ECU reset sequence
Yes. Personally I reset my ecu at the track, and did some runs before and after. No noticeable time improvements.
Spiro
Black/Black 2001 CL-S
Random Technology Cat
RED AEM CAI
Polarg M6 Roadlamps
Spiro
RED AEM CAI
Polarg M6 Roadlamps
The easiest way on the CL-S is to remove the cover on the battery, and disconnect the red wire for about 10 minutes. After 10 minutes put the red wire back on, and start the ignition. Do not press the gas. Let the car run for about 15 minutes at idle, and then close the ignition. After that you should be all set.
Spiro
RED AEM CAI
Polarg M6 Roadlamps
Spiro
RED AEM CAI
Polarg M6 Roadlamps
cool thanks, I probably did it then already without knowing it b/c I took out the battery when I install the CAI, so Im sure it reset when I put it back together.
CoMpTeCh HeAdErS
eIbAcH sPrInGs
AeM cAi
CoMpTeCh HeAdErS
eIbAcH sPrInGs
AeM cAi
Did you let it idle for 10-15 minutes? Its very important that you let it idle for a good amount of time.
Spiro
RED AEM CAI
Polarg M6 Roadlamps
Spiro
RED AEM CAI
Polarg M6 Roadlamps
Someday pigs WILL fly!
Are you sure about removing the POSITIVE side? I alwasy heard the NEGATIVE side. Too many sparks and chance of explosion with removal of the positive (red) side.
01 CL-S NightHawk Black/Ebony Bowling Ball Interior
Xephyr CAI
Polarg M6
Solaris 9005
Cupholder Ver 2.0 Part#77237-SOK-A02
gto2050 - The voice of absolutely no reason whatsoever!
Xephyr CAI
Polarg M6
Solaris 9005
I removed the Positive with no ill effects. You could be right..but I have had no problem removing the positive.
Spiro
RED AEM CAI
Polarg M6 Roadlamps
Spiro
RED AEM CAI
Polarg M6 Roadlamps
<font face="Verdana, Arial" size="2">Originally posted by spiroh:
Spiro
</font>
Spiro
</font>
Xephyr CAI
Polarg M6
Solaris 9005
If ground does the same thing..then I would probably go that route. Thanks for pointing that out.
Spiro
RED AEM CAI
Polarg M6 Roadlamps
Spiro
RED AEM CAI
Polarg M6 Roadlamps
What if you disconnect the battery for 10-15 minutes then restart the car, but dont let it just idle for 10-15 min. Will the ecu not reset? I disconnected the battery when I installed my plugs and CAI, but I dont think I ever let it idle(didnt know I was supposed to). Maybe Ill go disconnect and reset it again...
2001 Silver CL-S
Factory Spoiler, mud flaps, trunk tray
20% Tint
Silverknight Grille
Denso Iridium Plugs
AEM CAI & Pulleys
Comptech headers, sways, exhaust, and H&R sports on the way
2001 Silver CL-S
20% Tint
Silverknight Grille
Denso Iridium Plugs
AEM CAI & Pulleys
Yes the ECU Reset..but you did not give it ample time to adjust fuel/air ratio. Just disconnect again..and let it idel for 10-15minutes.
Spiro
RED AEM CAI
Polarg M6 Roadlamps
Spiro
RED AEM CAI
Polarg M6 Roadlamps
spiroh, are you sure ours cars don't constantly monitor that anyway? I am pretty sure that todays cars are always adjusting the mixture based on the what they are reading. i.e. higher altitudes, less O2...
I could be completely wrong
CoMpTeCh HeAdErS
eIbAcH sPrInGs
AeM cAi
CoMpTeCh HeAdErS
eIbAcH sPrInGs
AeM cAi
the proper way to reset the ECU (PCM) is to pull fuse # 13, clock/backup fuse (7.5A) from the passengers fuse box for 10 seconds
you dont have to let it idle at all
OR...you can use the honda diagnostic OBD tool...but i doubt anyone has it
99 TL
99 TL
<font face="Verdana, Arial" size="2">Originally posted by mr tl:
</font>
</font>
Silver 2001 CL-S with NAVI
- Mud guards
- Wheel locks
- Toyo T1S 235/45ZR17-97W* Proxies on 17x8" SSR Competition wheels (48lbs less than stock)
- Kevlar/SS Brake lines w/Brembos?
- Comptech headers & sways
- Silver AEM CAI
- 10 coats of Zaino magic
