Dyno, how much my car making
can some one give me a idea how much my car is doing?
i am running a comptech supecharger, comptech headers, custom 2.5 inch pipe, comptech mufflers, and a high boost pully
Whp and totall horse power.
Originally Posted by goldmemberer
Guys... Headers, S/C, HBP? Are you kidding me?
My guess is about 290-320whp & about 330-360hp @ the crank.
It should be easily in the upper half of the range mentioned if it is a 6MT. If 5AT it will be at or below the 290 WHP number.
Parting out 02 Type S :(
well than, you should have no problem achieving 300 whp. i dont know what octane gas you get in NY, but if its 92 or higher you should definately get at least 300 whp.
cls6sp03 got 305 i believe, and i think he is in cali with stock boost pulley, though he does have everything comptech makes on the car.
i would estimate somewhere between 300-310 whp as long as everything is running right.
Originally Posted by power3dfx
mrsteve, what does your boost peak at? if i remember correctly, it was 6.5-7 psi. The hbp is supposed to only peak at 5.5 psi.
I'll be posting a thread about that shortly... boost went even higher today
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
drop em like its hot
ny has 93 octane, so he should be making decent power on premium gas.
with race gas is it possible to advance timing to make more power with the SC?
Advance timing? No
Reduce the amount of timing retard? Yes
Consider this for a bench mark.
Red Rider has CT i/sc/h/b-pipe/e and HBP installed on his 5AT and was dyno'd by CompTech at about 290 WHP.
My car (6MT) has CT i/sc/h/b-pipe/e (no HBP) installed and was dyno'd by CompTech at 305 WHP.
Don't know what to make of your custom 2.5 inch pipe. It could either help or take away HP depending how it's designed.
Location: Somewhere between here and there, yet neither.
Originally Posted by cls6sp03
When I just had the CT i/h/b-pipe/e my 6MT dyno's at CT with 236/201 WHP/TQ
The best I got on dyno was 241.1hp torque199.3 temp 93% on july-03-03 this year best dyno was 235.5hp torque 195.9 on 11-13-04 temp was 55% the hotter it is out side the faster my car runs AT- 01-CLS 48K
Oakes
Wash & Wax
10-12-2015 11:17 AM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
