Dry gas?
Dry gas?
Nothing came up after searching.....I used to put dry gas in my old cherokee after every other tank (only during the winter months of course). Does anyone do the same with their CL's? I know its sole purpose is to suck up moisture in the tank, so i figure it can't hurt. Just seeing if anyone follows the same practice.
Gimmie my points Biatch!
Originally Posted by fusionnv
You mean a cleaner or something. Dry gas I though was when u fill a tank up with a gas (air kind) to remove condensation.
I've used it before and it's fine. It's essentially ethanol that will mix with the water and allow for the gasoline, ethanol and moisture to burn away.
Originally Posted by ThinJim
just go to wallgreens and buy a couple of bottles of rubbing alcohol.
