Does it take extra long to crank the car
Well I had this problem like the first 2 months I had the car but thought it was just my fault.
Usually when i start my car it takes like 1.5~2 seconds to start the car. Like I have to crank it extra long. one of my friends just got a 90 used accord and when he started the car it cranked with in .5 seconds and started. Also my previous cars (maxima) didn't have this problem. Started w/in .5 seconds.
I also read something in the NHST or what ever its called post a service bulliten about this.
Am i the only one?
CL-S
White/Ebony/Navi/Spoiler/Visor/Full Bra/Mud Guards/Acura Car Cover/Tint 20%,35%,5% on Sun Roof, Rockford 250a2 Amp w/JL10w6 / K&N Drop in Filter.Polarg m-6.
Comptech Headers,Springs,Sways, Eurolite Xenon Crystal high beams.Polarg m6
gtech 0-60 6.03 w/ 438 pound load. preheader.
Am i the only one?
CL-S
<font face="Verdana, Arial" size="2">Originally posted by NOVAwhiteTypeS:
Am i the only one?
</font>
Am i the only one?
</font>
CL-P....icy white!
moon roof visor
mud guards
genuine acura nose mask
genuine acura burlwood shift knob
polarg m-12 on blinkers
m-4s on internal lamps
m-4 on rear plate lamp
piaa bulbs on road lamps
K&N drop in filter
Catz XLO Driving lights
zaino polish
"i drive it like my grandma....j/k"
<font face="Verdana, Arial" size="2">Originally posted by icy CL:
i sometimes have this problem, too. i've been meaning to take it to pohanka but I no longer trust those svc techs. they seem to fix one problem then create another. but to answer your question, yes...i do have that same problem with the acura. my civic starts immediately...no hesitation at all!
</font>
</font>
1. Crank not working properly
2. Round Gray Spots in my paint *taking extra pair of sunglasses*
3. Paint under my headlight coming off . Literally falling off.
4. Retorque my headers.
5. Mysterious glowing VSA light.
anything else I should ask
Hey icy! may be if we both go and bitch they'll fix it for us. hehe lets take there loaners out for a test drive. ;D
CL-S
Here is Wayne's response on this back in April....... It never happened to me again so I did not bring it to him. I'll have Jens check next week when I have the headers re-torqued....
waynegCrazy Poster Posts: 116From: Maywood, NJRegistered: Feb 2001 posted 04-18-2001 04:28 PM The bulletin Jens is refering to (B01-001) addresses intermitent hard start after hot soak. The cure for that is to replace the fuel pressure regulator. The cold start, long crank is an issue we see most in fall and spring. It too is fuel related. The gas companies switch from Winter to Summer blends at those times and the change in vapor pressure from the fuel can cause wierd starting problems- particularly if you still have winter gas and the temp gets warm or summer gas and the temp gets cold. Not much you can do about this. The other issue is that you may be getting a slight loss of pressure in the fuel system after the car sits overnight. When you turn the key, the fuel pump is activated and pressurizes the system. It take a second or so to build pressure back up- thus the extra cranks. The best cure for this is to turn the key to on for a second or two then to crank. This gives the pump time to work and you should have a shorter crank. These really aren't problems and they do exist in most fuel injected cars.------------------Wayne GruenService ManagerPark Ave Acura
waynegCrazy Poster Posts: 117From: Maywood, NJRegistered: Feb 2001 posted 04-19-2001 08:49 AM Tel- we should probably do the Regulator?Pcm update on your car. Give us a call. We need to get some details. ------------------Wayne GruenService ManagerPark Ave Acura
2001 Silver 3.2CLS
Muds, Spoiler, Hardwire 8500, Polarg M-6 lamps, K&N filter #33-2178,
Comptech Headers, Sways, mufflers
Planning: SSR 17X7.5 GT1 Wheels, Brembo Brakes.
2001 Silver 3.2CLS
<font face="Verdana, Arial" size="2">Originally posted by tel1sps:
waynegCrazy Poster Posts: 116From: Maywood, NJRegistered: Feb 2001 posted 04-18-2001 04:28 PM The bulletin Jens is refering to (B01-001) addresses intermitent hard start after hot soak. The cure for that is to replace the fuel pressure regulator. The cold start, long crank is an issue we see most in fall and spring. It too is fuel related. The gas companies switch from Winter to Summer blends at those times and the change in vapor pressure from the fuel can cause wierd starting problems- particularly if you still have winter gas and the temp gets warm or summer gas and the temp gets cold. Not much you can do about this. The other issue is that you may be getting a slight loss of pressure in the fuel system after the car sits overnight. When you turn the key, the fuel pump is activated and pressurizes the system. It take a second or so to build pressure back up- thus the extra cranks. The best cure for this is to turn the key to on for a second or two then to crank. This gives the pump time to work and you should have a shorter crank. These really aren't problems and they do exist in most fuel injected cars.</font>
CL-S
Make sure you mention the PCM update to your dealer....
2001 Silver 3.2CLS
2001 Silver 3.2CLS
Thats it, Im going to the dealer this weekend to bitch about:
</font>
</font>
CL-P....icy white!
moon roof visor
mud guards
K&N drop in filter
zaino polish
pumpkin escobar
</font>
</font>
HEY i had a car bra on too. may be that's why our paint is coming off. but mines on the passenger side. I was about to put touch up paint on it but, i want to show the dealer whats up.
and whats the pcm update?
CL-S
CL-S
</font>
</font>
CL-P....icy white!
moon roof visor
mud guards
K&N drop in filter
zaino polish
I can go tommrow if ya want or sometime next week.
<--------- Natural Bitcher and Natural Pain in the ASS that LOVE TO MAKE A SENCE at a dealer ship
Typical Asain.
You might want to pretend u don't know me when I start to bitch.
CL-S
Typical Asain.
CL-S
</font>
</font>
CL-P....icy white!
moon roof visor
mud guards
K&N drop in filter
zaino polish
PCM update mentioned by Wayne...... That and the potential regulator replacement was his recommended fix for the long crank problem
2001 Silver 3.2CLS
2001 Silver 3.2CLS
Typical Asain.
</font>
Typical Asain.
</font>
CL-P....icy white!
moon roof visor
mud guards
K&N drop in filter
zaino polish
oops...NOVA, can't make it tomorrow. i could make it next week. just let me know!!!
</font>
</font>
CL-S
Well I work in herndon ( 5 min from pohanka) so why don't u email me next week. i can go mon or wed and i get off around 6 but can leave early if I need to.
</font>
</font>
CL-P....icy white!
moon roof visor
mud guards
K&N drop in filter
zaino polish
handsom-hustla
11-13-2015 05:04 PM
nanos
11-12-2015 08:41 PM
