Does anyone else have tire wear issues with Comptech springs?
I tell you, this is driving me crazy.
To set the stage, I have competch springs with Koni shocks. I have had my car aligned no fewer than 3 times on a Hunter road force analyzer and the results have always been within spec., with the exception that the rear was out of camber by a a tenth or hundreth of a percent (I don't remember, but it was next to nothing).
I rotate my tires every 10-12k miles and the GD things keep wearing on the inside, most notably on the back tires.
So far I have been through the stock tires (this one they screwed up because they didn't align it after the install--idiots), a set of Potenza RE730s, a set of Kumho Ecstas and now my Kumho MXs. BTW, I have 75000 miles on the car--you work out that average!
While I'm becoming very familiar with the handling characterisitics of many different tires, this has got to stop.
Is anyone else having this type of wear? I'm hoping to at least get through this set for the summer but then I'm right back in the same boat.
What's up with this?
Where is my super sauce?
After my Comptech spring installation, Jens (PAA guru) suggested that I rotate my tires every 5K miles -- he suggested that any lowered car (even the modest Comptech drop) will wear tires more frequently and more frequent rotation is the key to extending tire life.
Why are you rotating tires at 12K miles? Even the manual suggests a 7500 mile rotation interval.
I also have CT springs and konis installed and had an alignment. I have my tires rotated every 5k and now after 15k on my tires I haven't run into any excessive wear issues.
Re: Does anyone else have tire wear issues with Comptech springs?
and 3 sets of tires for 75K is decent in my mind...
Half the fun is smoking them off before you go get new tires that day..
I rotate mine every 5K miles. 10K miles is way too long even with a stock setup. No uneven wear. Also you might want to get a camber kit as well. I know the CT drop isn't supposed to need it, however there have been a few people here who had wear issues & that fixed it.
I'm not sure the camber kit will add anything if he's in spec.
FWD cars (in my experience) will wear front tires fast when you don't rotate.
I also agree with Smitty -- 3 sets in 75K is not too bad for the sport-lux coupe that we have. Don't buy sport oriented tires if you want them to last forever - if that's your goal then downgrade to 16" wheels and get some loooong lasting touring tires. Just don't turn to often...
Originally posted by ktgumbo
I would just pick up some tires witha 400 rating.
and the NOISE those fuckers are going to produce is going to sound like a 4X4 truck on 33 inch tires rolling down the highway.
With my 225 re730's(comptech springs/stock shocks), The cl-s had inside tire wear but I still got 30k miles out of them,, My 235 re750's have about 15k miles on them and I still don't see any inside wear,,, I rotate/balance every 5k miles... after the switch to this set up I will never go back to stock again , it's still like driving a completely dif car than stock. IMO ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Well, even if I went with harder rubber, they are still going to wear unevenly.
Clearly, I only ever expected to get a good 20k miles out of the Z rated tires, but I would hope that it would be an even-wearing 20k instead of always having the insides of the tires wearing out.
What I think you guys are missing is that there is clearly something else going on here--why are my rear tires wearing so unevenly on the inside? I simply don't believe that rotation at 7500 vs 10 or 12 k is going to make that much of a difference--the simple fact is that the suspension setup is wearing tires unevenly--If I rotated them every 20 miles the car is still going to eat up the insides of my tires in a very non-uniform way.
And, I would guess that those of you rotating your tires every 5k miles are in the vast minority on that one. That seems a bit excessive unless it takes you a year to rack up 5000 miles.
There is no way your alignment is within spec then... there is something your not telling us or you were totally misinformed by the people who did your 4 wheel alignment..
Do as someone suggest and get a camber kit... We are telling you the answer but it sounds like your expecting some miracle from us..
I rotate my tires every 5K.. bottom line.. I do not have any uneven wearing issues... I have Comptech drop with my Stock shocks....
You can always take the springs off and go back to riding around town like a dork with 4X4 ride height.... that should solve your problem..
With my king size 3 1/2” ton floor jack I can swap all 4 tires in only about 45 minutes.
My new Toyo Proxes 4’s were just mounted on the rims yesterday and are going on this weekend.
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
My Falken Azenis tires didn’t were unevenly; they just plain WORE OUT in only about 14,000 miles.
But I do tend to toss the car around a bit.
Shawn S
GEEZER
Originally posted by Shawn S
I rotate every 3,000 miles.
My new Toyo Proxes 4’s were just mounted on the rims yesterday and are going on this weekend.![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
But I do tend to toss the car around a bit.![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
Shawn S
Shawn S
I just had new Toyos put on a few weeks ago. My old ones looked bad. You are in for a real treat. Theres nothing like a fresh set of toyos. So smooth!!!!
Oh well, I guess it's time for new tires and rotation at every oil change.
As for the alignment, I actually was doing it with my friend who is a master tech so I know it was done correctly.
I guess I was naive in thinking that 10000 miles is suitable for a rotation time. I guess in reality that's like rotating a 70000 mile tire after 35000 miles.
That's OK--I like getting new tires anyways. Maybe the Potenza 750s this time.
Over and out.
Over and out.
///M POWER
1 Post
i have uneven wear with my eibach pro kit cause i didnt have time to get a alighment, but when the toyos go on saturday, i get a oil change and alighment at acura on monday and i'm gonna rotate these toyos every 3-4k when i get oil changes
Re: Re: Does anyone else have tire wear issues with Comptech springs?
Originally posted by AZMerf
Make sure you are getting all four wheels aligned every 6 months (in addition to rotating your tires).
OK, now this just seems crazy. There is no way a car should need to be re-aligned every six months. Lucky for me my good friend takes care of all of this stuff for me but if I stuck to that program, and the tire rotation program mentioned earlier, we're talking about spending rediculous amounts of money on TIRES!
Let's see, what does a rotate and alignement cost:
Rotate: at the dealer 50-60$
Alignment: at the dealer: 120-140$
If I drive 20k miles in a year I would be talking about 240-280 for the alignments and another 200-240 for rotation for a total of approximately 440-520$ a year on tire maintenance.
Come on now, this is not a Ferrari we are dealing with. For that cost you might as well just run a set of tires for 12 months and then get new ones. Forget about rotating them!
My tire install place (NTB)offers free rotate and balance every 5k,, for me this is about every 3-4 months. Something to think about when you buy tires... I also used tirerack for prices and they matched them and then charged me a extra $10/tire for mounting. Sears sometimes will do this also.
Adventurist.
Discount Tire Centers offers free lifetime alignment and rotation for $130+. I use that. Two alignments already paying more than what I paid for the package.
My rear camber is off by 0.5 degree. I may need a camber kit also.
cycdaniel
12-17-2019 10:58 AM
asahrts
09-04-2015 05:55 PM
