Does anyone else have a squeeky Comptech spring??
My drivers side front spring is driving me crazy!! It squeeks when I got over bumps, up driveways etc.
I talked to Comptech about it but trying to get them to admit to anything is impossible.
Anyone?? It's been to the shop 2 times to get it fixed w/o success.
2001 Satin Silver Cl Type S.
Comptech:Headers, Springs & Sways
AEM CAI
Toyo T1S Proxys 235/45/17
35% Llumar metallic tint
My Car
[This message has been edited by Mike (edited 04-10-2001).]
AEM CAI
My Car
what did they do both times you were there?
what they should have done is raised your car, and move the isolators to the areas where the springs are contacting each other, that is, if this is where the noise is coming from.
look at your springs at where they contact, if they are touching each other, you will see rubbing.
'01 cl-s blk/blk :: comptech headers, comptech springs, comptech sway bars
Only the rears have the isolators. The problem is probably between the spring and the perch. It's a not a metal on metal rubbing. It's a rubber on metal squeeking.
Thanks for the reply.
AEM CAI
My Car
AEM CAI
My Car
Bagged hybrid
If it were the coils clanging, the sound would be metal against metal...but the sound I'm getting sometimes (probably what Mike is referring to also) is a rubber squeaking noise when the coils compress. I only get it when it's cold outside. The silicon oil didn't work? Sorry Mike...I'm puzzled.
no prob. well, i can hear the front springs compress when going up something like my driveway. .
I haven't used the silicon because it's such a pain to get it to the perch cleanly.
That's only a short term fix anyway..
Where have you been??
AEM CAI
My Car
AEM CAI
My Car
<font face="Verdana, Arial" size="2">Originally posted by Mike:
</font>
</font>
If you could ever get those springs off, I would suggest putting some tubing or heat shrink over the end coil (if possible) and or wrapping the Teflon tape over the offending end(s). You just are hearing some slippage, so if you can get the spring ends to slip on the rubber, you’re probably ok.
I still wonder about the progressive coils in back, but they have some "bulge" yes/no?
Silver 2001 CL-S with NAVI
- Mud guards
- Wheel locks
- Toyo T1S 235/45ZR17-97W* Proxies on 17x8" SSR Competition wheels (48lbs less than stock)
- Kevlar/SS Brake lines ordered
- Comptech headers & sways ordered
- Silver AEM CAI ready
- 6 coats of Zaino magic
This is just a guess but it sort of sounds like the spring perch is not assembled correctly.What can happen is that when the springs where put in one of the rubber isolators that is in the upper spring perch shifted during reassembly.This would allow the upper coil of the spring to contact the metal of the perch possibly making this noise.Another possibility is that the bottom coil of the spring is not seated correctly on the bottom perch.Jens
1992 mazda Miata lowered with Eibach springs KYB AGX adjustable struts Sparco racing buckets 4 point safety harnesses Momo steering wheel lo profile headlite system with PIAA superwhite bulbs Custom audio system Custom gauges Jackson racing supercharger with header and Greddy cat back exhaust and a ton of other stuff 2000 Honda Civic on APEX coilovers Full Alpine Audio system factory fogs with Piaa bulbs Catz ZETA high beam headlamp system H.I.D. Xenon low beam tinted, custom taillites and on and on
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
