Do you get negative camber wear even with a mild drop?
Honkey
I usually drive my car around with what would be equal to about a 1.5" drop...and my back tires really show wear in the inner most edge very quickly. I would say they are bald after about 6k miles....only about the inner 1" of the tire. Anyone have this issue or is my toe probably off or something causing them to wear prematurely. Thanks in advance.
i think it may be toe. i had the same kind of wear in the front only with comptech springs. after an aligment, it was discovered that the toe was way off.
the rears wore normally.
3-piece FTW
You should get an alignment and go into an alignment place with the specs you daily drive at.. if you need a camber kit I say get one but I ride slammed and no camber problems at all..
![what](https://acurazine.com/forums/images/smilies/what.gif)
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
emailnatec
29
09-28-2018 04:27 PM
