DIY on windshield washer nozzle/??
Old Oct 4, 2012 | 01:50 PM
qwpobird's Avatar
Has any one done windshield washer nozzle replacement before?
My passenger side is not working now.
Is it easy??
Thanks in advance...
Old Oct 4, 2012 | 02:07 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
changing ur daytime running light is harder.
yes it's beyond easy
Old Oct 4, 2012 | 02:25 PM
brian6speed's Avatar
Lone Wolf
I just removed my fluid reservoir and the lines. I left the nozzles on tho. It seems like that black plastic cover is easy to break or damage when trying to remove.
Old Oct 4, 2012 | 08:26 PM
yungone501's Avatar
J-series addict
Make sure you buy new nozzles. If you haven't tried CLR, do so! This is the product that was initially only available on TV but has made its way to places like WalMart and is great at removing calcium deposits from small lines, nozzles and orifices. Two out of three usually are taken care of simply by doing this. But don't expect immediate results. Use it a few times per day for 1-2 weeks. If there's no improvement or fix, move on...
Old Oct 4, 2012 | 11:26 PM
qwpobird's Avatar
are you talking about this product? (URL link) just want to make sure ... thanks
as for the black plastic cover, should I just pop out chips? Thanks
Old Oct 5, 2012 | 07:13 AM
yungone501's Avatar
J-series addict
That would be the one, yes sir.
Old Oct 5, 2012 | 02:41 PM
qwpobird's Avatar
Thanks I'll go look for it today
Old Oct 5, 2012 | 03:09 PM
if things are that decrepid i would replace the washer lines as well.. just so u int doing things twice kinda thing.
Old Oct 5, 2012 | 05:31 PM
yungone501's Avatar
J-series addict
Agreed....if the CLR does not work.
Old Oct 6, 2012 | 12:24 AM
odds are it's plugged with a lil grain of sand/debris. and that just plugs the nozzle right up. I never tried clr or any product like that for that scenario and i have it, never even thought to attempt it cause i always thought it was something solid that;s plugged it up. vs calcium/mineral buildup.
we'll see if it works.
if u wanna save it 100%.. remove it from the car. leave it in the clr and then use compressed air and blow through it backwards. i cannot see any reason why that isn't a sure thing
Old Oct 6, 2012 | 12:37 AM
techartgt3's Avatar
7th Gear
I had the same problem with mine, I just tool off the nozzle and soaked it in some gasoline, then just blew air through it. Works like a charm now.
Old Oct 6, 2012 | 02:10 AM
mikebikelife's Avatar
@Mikeshlong On IG
Lol , went on a 400+ mile trip today and drivers side not working, boom thread .
Old Oct 6, 2012 | 08:15 AM
yungone501's Avatar
J-series addict
Although calium buildup can/does occur while using the premixed washer fluid concentrate, seems to be MUCH worse when the reservoir is filled with water only or low washer fluid concentration. This, of course, would be from obvious reasons.
Old Oct 7, 2012 | 06:47 PM
@Mikeshlong On IG
Did it yesterday , soaked the nozzle in clr for about 15 mins, took a spray bottle with water and forced water each way in the nozzle . Put back on and boom presto fluid out of both . Only issue was the screw holding it to the hood stripped, but I fixed that as well .
Old Oct 8, 2012 | 12:47 AM
qwpobird's Avatar
I haven't done mine yet,,, coz,,, I couldn't pop out the black chips to remove the black cover. - ________ - any hint?
Old Oct 8, 2012 | 07:32 AM
yungone501's Avatar
J-series addict
Why remove it? Pour a small amount right into the reservoir.
Old Oct 8, 2012 | 12:59 PM
silvervtec96's Avatar
Back to a MT!
My driver side stopped working, took it apart to see what the issue was... the little one-way valve failed (and broke). Used duct tape in the mean time and works, have a new one-way valve in the car, just need to find the time to replace it. Was about $5...
Old Oct 8, 2012 | 01:36 PM
Dspr_02's Avatar
When I bought my CL back in march, the driver side was screwy and seemed to have very low pressure. I just ran about a gallon of RainX through mine and it seemed to clear it up. Another 2 gallons later (and a 6000 km road-trip) and it still works good as new.
Persistence is another solution to this problem, it worked for me, but no guarantees for you or anyone else...
Old Oct 8, 2012 | 06:35 PM
qwpobird's Avatar
Oh, I thought I have to take the cover out and clean the valve and the tubes
Old Oct 8, 2012 | 09:29 PM
yungone501's Avatar
J-series addict
For the nozzles that are extremely calcified, that's the logical solution. And by "extremely", I mean the nozzle is only allowing a dribble or nothing at all. Cases in which the nozzle is not spraying in its full range or if you just want to maintain its internal cleanliness, adding the CLR to the reservoir is acceptable. Either way, the stuff works.
Oh and one more thing, I don't recommend using this in conjunction with washer fluid. I've never done this but mixing chemicals/solutions is never recommended EVER. Many would be suprised what mixing a few common, household chemicals could do and what danger they could pose. Just thought if throw that in there...
Old Oct 10, 2012 | 05:39 AM
aznboi2424's Avatar
Mine used to be really weak. I pulled the lines out and turn out that there was some crud/dirt in there and just blew it out.
Old Oct 19, 2012 | 08:00 PM
qwpobird's Avatar
great,,, I took a look yesterday,,,,,,
no tube nor nozzle was jammed,
it was just the a tube disconnected with the valve......
OMG - _ -" easy fix,,, it took me 1 sec to connect them
Mike734
Dec 10, 2021 01:25 PM
tsx_boy
Dec 13, 2019 08:33 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
rhdune16
Sep 28, 2015 11:31 AM
Cexarin
Sep 23, 2015 07:43 PM
