DIY Big Three Upgrade ?
To many cars in my garage
Has anyone ever done a DIY on the big three upgrade ?
Im about too do it, probably this week some time and I was wondering if anyone has done a diy because it would make my life alot easier
LOL, if not I may do one
these are all using big gauge wiring (8awg,4awg, or even 0awg)
1, connect wire from positive on the alternator too positive on the battery
2,connect wire from battery negative to chassis
3, Engine ground to chassis
It just helps the electricity flow better, but its kinda pointless if you dont have a system
Man you posted before I got a chance![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
I just wanted to know where you hooked the grounds up and how much wire I need before I go to the store I hate going back for more stuff and Im using 0awg so I dont want to buy too much $$$
3.7L Nitrous Breathing CL
I could be wrong but,I think I used 10-12 feet.
It's been awhile.
The - to the engine is the same as the factory -wire.
And the - to the chassis is the factory -wire too by the radiator support area.
I did not remove the factory wire just doubled them with 0 gauge on top and big connects.
It's been awhile.
No my alt is at 12amps at a stop so I wana do the big three and see if it helps but I think im gona have to replace the alt
thanks rick I think I will just measure the stock wiring to figure out the length I dont know why I didnt think of that
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Don't people search anymore? I used the diy from this forum, the 2nd gen forum
^^ thanks ive already done that for 20min before I started the thread and have continued to do that all afternoon and all I found was this
https://acurazine.com/forums/showthr...ht=Big+upgrade
If you know where the DIY is could you tell me
B A N N E D
f***ing simple :shakehead, all i did was search for "big three", with the username being "Rajca", and under the results it was the third thing
anyways:
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-big-3-a-692969/
anyways:
I just found it at the same time you did I thinks there something wrong with the search because it kept cutting 3 and I didnt find it that way I found it this way
Any ways thanks
Any ways thanks
2 RF 300-1
But Im running at 12 amps when im not moving and my stereo is not in right now (I take it out in the winter) but its low because I have an underdrive crank pulley and I think I need a new alt
B A N N E D
btw people have run much larger amps with out ever doing the big three (i got a 500w alpine, with out ever touching the cables or the alternator (still origional at 109K), and i also have a underdrive pulley installed also, and i do play my stereo at idle no problem
B A N N E D
without anything else on, but just the headlights/running lights on
(at the battery itself???, i would also check it at the alternater terminal itself also first, to make sure there is not too much resistance in the wiring)
then i would switch out the underdrive pulley as the next step to see if it comes back normal (which it might)
but as long as the wiring itself is still good, i would say the alternater itself is bad (still should be putting out more then that even with a underdrive pulley on there)
![what](https://acurazine.com/forums/images/smilies/what.gif)
It was going down to just above 13 before I put the underdrive pulley in, so I think its the alt too
Im still doing the big three just ordered the parts. I will see what that does and then if it doesnt go to mid 13s then I will do the alt. but I wanted to do the big three anways because My amps are hungry (Stupid RF)
But I am running HID fogs as well as HID headlights not sure how much power that is using
BTW I love that DIY it was exactly what is was looking for and the price on the wiring was awesome too (I pay $4 a foot for 0 awg here)thanks Im retarted when it comes to searching and I search both TL and CL side and Then I got it through the audio side and through a link on another post
What is the purpose of this? Correct me if I'm wrong but the alternator already has a regulator on it, and when that fuse blows your battery is gonna stop charging. So unless you're checking that fuse every time you get in and out of the car odds are you're gonna blow it without knowing it and wind up with a dead battery.
Its incase the power wire comes lose and grounds out it could cause a fire thats the only reason
there should be no other reason the fuse would blow assuming you have a large fuse 250amps the alt would never put out that much though
B A N N E D
and still better with a discharged battery , then a burned down car, and anyways the charge light should also be on, if the fuse does happen to blow
No not im not arguing that the loads that come stock are crazy. But what I find really weird is when I click the ligths once so just back lights and side markers(which are custom leds 24 to be exact so hardly any power and all my interior lights are leds as well) it really dips
Btw as soon as I go its around 14.2
B A N N E D
![EEK!](https://acurazine.com/forums/images/smilies/eek.gif)
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
My alt been pretty low for like a month now so Im going to do the big three when i get my parts and hopefully it holds out a little longer cause my wife is gonna kill me if I have to buy an alt I just payed 2900 for my tranny
Whats up with RDX owners?
IIRC 12amps is correct for idle. You need to bring it up to around 3k rpm to see 14.
I did a quick search and you should be at 13.7-15.8 at idle with nothing on. But it does vary with temperatures.
How would 15amps blow out our electronics when at higher rpms the alternator sees 100+?
