civicdrivr
close
- Join DateJul 2008
- LocationVA
iTrader Positive Feedback100
iTrader Feedback Score(9)
Liked:8,746 Times in 5,159 Posts
FML.
Thats the passenger axle inner joint. As most of you know, there is supposed to be about a 3" spindle on that end. Where is it, you ask?
Right there!
I just drilled a hole into the center of it. Once my sister in law gets home I can take her van
to pick up a lag bolt and the replacement axle.
This is the fourth axle in 2 years, third in three months. The first snapped in the center. The second and third ate up the bearings in the inner CVs, and now this.
Luckily it happened as I was pulling into the driveway. I gave it a little gas, got up to about 4k rpm, then POP - no power. At least it didnt leave me stranded this time.
Mods - Who do I contact for more info on starting a group buy feeler thread?
Right there!
to pick up a lag bolt and the replacement axle.This is the fourth axle in 2 years, third in three months. The first snapped in the center. The second and third ate up the bearings in the inner CVs, and now this.
man that blows!. What type of axles were they? I was so afraid about having problems I decided to buy Acura ones if I kept the car. Of course that was also 1 reason i got rid of it as the cost of them plus install was $900.
civicdrivr
close
- Join DateJul 2008
- LocationVA
Quote:
New, not remanufactured, GSP axles.Originally Posted by fuzzy02CLS
And who do I contact about starting a GB feeler thread?
03 CLS-6
1foxbody
03 CLS-6
close
- Join DateAug 2008
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:123 Times in 92 Posts
Lone Wolf
brian6speed
Lone Wolf
close
- Join DateFeb 2003
iTrader Feedback Score(5)
Liked:498 Times in 399 Posts
I'm still waiting/deciding which axles to go with. I would be down on a gb.
Damn...maybe I just never had axle issues, but do you mind letting me know what you think is causing this issue you are having? In other words, why is the axle breaking so frequently for some of you? Is there something I should be watching for with my axles?
lowrd on tein CS biatch
civic,,, ur nor even boosted right? and ur breaking axles.
i just don't get it.
u must abuse the living shit outta ur whip
p.diddy
close
- Join DateMar 2008
- LocationMaryland
- Age41
iTrader Feedback Score(3)
Liked:729 Times in 423 Posts
hes pushing boosted numbers.Originally Posted by CL-S progression 01
civic,,, ur nor even boosted right? and ur breaking axles.i just don't get it.
3.7L Nitrous Breathing CL
So this is what I got look forward too ,great.
good thing I can change them in like 10 minutes flat.
LOL^^
how much power u got under there civic?
3.5 psi
gnuts
3.5 psi
close
- Join DateSep 2007
- LocationCanada
- Age43
iTrader Feedback Score(1)
Liked:798 Times in 636 Posts
290whp/270wtq? Something like that. more then s/c on low boost.
I thought there was a member who had custom axles made once to handle like 500hp.
Lives in Boost
Quote:
http://www.gatorracingaxles.com/index.php
I've posted this a couple of times but for some reason it doesn't gain traction. I haven't had to replace mine since (2 years give or take) and I drive pretty hard on the blower.Originally Posted by 1foxbody
They are your friend lol.http://www.gatorracingaxles.com/index.php
*knocking on wood*
So is it from the torque which doesn't seem THAT high or age/wear and tear? Something else to save for?
Lives in Boost
Quote:
270tq to the wheels for a FWD car is definitely THAT much on an OEM style axle Originally Posted by g1underground
fuck i wishhhh i had 270TQ that'd b sweet 13s all dayyy
03 CLS-6
1foxbody
03 CLS-6
close
- Join DateAug 2008
Quote:
*knocking on wood*
Exactly Originally Posted by CL-Future
I've posted this a couple of times but for some reason it doesn't gain traction. I haven't had to replace mine since (2 years give or take) and I drive pretty hard on the blower.*knocking on wood*
Anyone that is having problems with breaking axles needs custom axles period. You will never have to worry about breaking them again. Problem solved!
Quote:
400 Originally Posted by CL-S progression 01
I looked into the gator ones. But at the time no one was running them in this application. I didn't want to be the test mule. I'd try those now I know someone runs them.
civicdrivr
close
- Join DateJul 2008
- LocationVA
The hole in the center is the one I drilled and tapped so I could pull it out of the intermediate shaft.
From what Ive heard, the bearings in their axles are no stronger than stock. But, I will give them a call though and find out some info regarding the racing axles.Originally Posted by 1foxbody
Quote:
Ill let you know. I need to find out how similar the CL axles and the 6th gen Accord axles are. If they are similar, I suspect a few more people would be interested.Originally Posted by brian6speed
Quote:
Sticky tires, stiff suspension, stiff mounts, and stiff clutch. Something has to give. Id much rather break the tires loose though Originally Posted by exl124
Quote:
I didnt build the engine so I can drive like a grandma Originally Posted by CL-S progression 01
Quote:
As of December 2010 - 294/275. Originally Posted by CL-S progression 01
As of December 2011 - More
Quote:
I believe age had something to do with the first set I broke, since the shaft snapped. The set that broke in October were a little over a year old, and I broke those when I went WOT from a 40mph roll (trying to race two members on here). Its possible (and likely) that this one was defective. The split was just too damn clean.Originally Posted by g1underground
Quote:
I didnt want my tax refund going into the car, but it seems like I have no choice Originally Posted by 1foxbody
Lone Wolf
brian6speed
Lone Wolf
close
- Join DateFeb 2003
I and others have mentioned these many times before. Not sure on quality or if they are beefier than stock.Originally Posted by 1foxbody
wham bam thank you ma'am
i went through 6 axles in a month when i got my license back. i was pissed off. but life time warranty so i saved some money. lmk what axles u get and how they perform
Contact God, er, Ron A.Originally Posted by civicdrivr
New, not remanufactured, GSP axles.And who do I contact about starting a GB feeler thread?
What has been added for more power.
really surprised you got the shaft out with out something like a dent puller.
Is that custom stainless headers there in that pic.
I hope all the welds were grinded down on the inside.
Because if thats stainless,as ugly as the welds look on the outside is probally as ugly as it looks on the inside.
civicdrivr
close
- Join DateJul 2008
- LocationVA
Quote:
Thanks Originally Posted by saiko_cl_duck
Function over form. And dont judge a book by its cover.Originally Posted by richardparker
Is that custom stainless headers there in that pic.I hope all the welds were grinded down on the inside.
Function over form I can agree with to a point.
If the inside of the pipes look like the out side of the pipes at every joint what do you think that will do ?
If they were grinded on the insides then I agree,if not...
Aman
Your Friendly Canadian
close
- Join DateDec 2007
- LocationToronto, Ontario
- Age33
Liked:1,506 Times in 1,057 Posts
4000 rpm pulling into your driveway?
civicdrivr
close
- Join DateJul 2008
- LocationVA
They are grinded on the inside. Hence my "dont judge a book by its cover" comment.Originally Posted by richardparker
Function over form I can agree with to a point.If the inside of the pipes look like the out side of the pipes at every joint what do you think that will do ?
Quote:
Its a long driveway Originally Posted by Aman
zeta
close
- Join DateAug 2003
- LocationS. Florida
Liked:2,218 Times in 1,784 Posts
Quote:
It's good to see that there was at least enough room for you to maneuver a drill under there. Originally Posted by civicdrivr
civicdrivr
close
- Join DateJul 2008
- LocationVA
Quote:
Just enough, with a long drill bit Originally Posted by zeta
I Wanna Beer
Haven't had an issue with my CL but went through that with my Cobra. ISR wasn't built for pushing +600ft-lbs. Almost went solid rear.
fsttyms1
close
- Join DateAug 2002
- LocationAppleton WI
- Age51
Liked:3,068 Times in 2,123 Posts
Ive been thru 2 so far. As soon as the new engine goes in im suspecting i will need much better ones myself.
The new engine with the knifed edge crank ?
What does the motor got.
Spining up the rpms faster will sure make you more prone to snap a rooni.
StreetKA
close
- Join DateOct 2008
- Age39
iTrader Feedback Score(8)
Liked:575 Times in 410 Posts
Quote:
the biggest reason they break alot is that you lower the car that much so the axle actually works at different angles that it was designed to... also power adders suspension and good tires... breaking an axle is not fun and im not talking about towing and fixing the car so you can drive again but 6 speeders must be carefull and really better save up for custom axles because when it breaks you can damage differential bearings in your tranny... some of us have an experience on that alreadyOriginally Posted by exl124
here's mine
Aman
close
- Join DateDec 2007
- Age33
For some reason, I imagined drive axles would be thicker...
03 CLS-6
1foxbody
03 CLS-6
close
- Join DateAug 2008
This company is also better than gator axles try them out. That's who I'm going to use once I eventually do break a axle lol.
http://www.driveshaftshop.com/
civicdrivr
close
- Join DateJul 2008
- LocationVA
Yes, Id love to get DSS axles, but at $900 for a set, its a bit pricey. I am going to contact them about doing a group buy though. The Gator Racing guys dont like to return phone calls, so I doubt theyll get my business.Originally Posted by 1foxbody
This company is also better than gator axles try them out. That's who I'm going to use once I eventually do break a axle lol.http://www.driveshaftshop.com/
