Dealership's CEL diagnosis
I have 3 codes that read:
Primary O2 Sensor Failure
Lateral G Sensor Failure
ECM relation Failure
WTF is a lateral G sensor failure and an ECM relation failure?
Registered User
Originally Posted by derelict
They'd pat us on the back for that...
Yes they would.
Unfortunately, Brandon has been promoted to Manager so I have to deal with some no nothing dolt over the phone.
I'm headed there now
![:O](https://acurazine.com/forums/images/smilies/embarrassment.gif)
Subie Dubie
Originally Posted by allmotor_2000
The lateral G is one of those codes dealers use to say you 'raced' the car!
![Drag](https://acurazine.com/forums/images/smilies/drag.gif)
The lateral G sensor is use with the VSA system to determine what you are doing and intedning on doing. Such as the wheel turned in one direction but the car spinning int he other direction, VSA knows somethign is not correct. The sensor tells the ECU what way the vehicle is travelling.
Yes the codes were present without the UniChip.
EDIT:
Well the CELs were present without the UniChip. The CEL, VSA, and "!" lights all came on at the same time about 30 seconds after I was driving over a bridge at WOT... while crossing the bridge I went over a steel joint in the bridge that wasn't 100% level with the road surface. This caused the VSA to kick in briefly (2 seconds). After that the CEL came up and so did the VSA and "!" lights. Seems very odd that the O2 sensor and "lateral G sensor" came on at the same time after that incident.
EDIT:
But had they occured before??
The reason I ask is that is a lot of sensor inouts to go at the same time. I'm not blaming the Unichip, I just wondered if something happened to the factory harness during the installation.
This event occured about 3-4 weeks following my custom UniChip tune, so yes the UniChip was installed and had been installed for quite some time without problems.
Just providing my $0.02 as when multiple problems occur for my I try and look for a common denominator. But in the end, they could all be just coincidence that they occurred at the same time.
Steve,
Could the "ECM relation failure" point to a bad wire in the harness?
They still haven't figured it out. (Probably too busy to get around to it). They did replace the 02 sensor and that code went away.
Damnit I wanted to go to the track tonight too. Maybe I should just go in the '04 TL loaner they gave me
![Woot](https://acurazine.com/forums/images/smilies/woot.gif)
![Chuckle](https://acurazine.com/forums/images/smilies/chuckle.gif)
I have no idea if it is the ECU. Considering it happened right after I hit a bump, I tend to think it is a mechanical problem rather than electrical. Either way, I have an excellent relationship with Tischer and I know they'll take care of it.
One thing I left out...
When I start the car, the CEL comes on right away. The VSA and "!" lights usually take 2-3 seconds more to come on.
Now if right after I start the car I rev the engine up (while in Park) let off, then rev up, etc, etc... the VSA and "!" lights do not come on until 2-3 seconds after I stop the revving.
My car is ready. They replaced the O2 sensor and all 3 codes went away.
Brandon took the car out for a drive (about 17 miles) and said the VSA worked fine; I'm sure he tested it out to its fullest ![Racing](https://acurazine.com/forums/images/smilies/racing.gif)
I'll be picking it up this afternoon. Everything fell under extended warranty coverage with the exception of my $50 deductable.
Don't know why it had those other two codes too. Weird...
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
![Scratch](https://acurazine.com/forums/images/smilies/scratch.gif)
The lateral G sensor is used in conjunction with wheel sensors, a yaw-rate sensor and various heuristics to control the operation of the VSA.
I'm not sure about the "relation error code," but I wonder if the errors + your little black box that's tweaking the data the ECU is seeing could also cause an exception to be tossed in the ECUs code.
I'm sure it is possible. But even though the VSA and "!" lights were on it seemed to me like I still had VSA active. I didn't have a chance to try and make it slip under wet conditions (i.e., leaving the line with too much throttle to make the wheels spin) but occasionally I felt like it was engaged during "spirited" driving conditions.
What matters now is that it is working 100% normal.
Now when I pick it up today I need to talk to him about adding a little 5.5-6.0 PSI with a new "bolt-on."![Zoom](https://acurazine.com/forums/images/smilies/zoom.gif)
Anyone want to buy a UniChip cheap? $400!
The indicators being displayed as an "error code" should not effect the dedicated subsystem that is integrating the yaw, lateral acceleration, and wheels speed info.
What I'm commenting on is: once you "diddle" with input signals, you are wandering into unknown territory. Not only is it difficult to test a few lines of "C" or C++ code, but it gets even more difficult to know what is going on when "expected" sets/ranges of data have been skewed/altered.
I'm not saying that's something is amiss or bad -- I'm just pointing out that once you start ganging up various systems and "fooling" with data, you can get some "strange" results. I've worked on a lot of multiprocessor systems and some of the errors and "weird" conditions were non-obvious and that was with everyone working under the same umbrella.
From the Helms:
"When the VSA system indicator and MIL are both ON, troubleshoot the PGM-F1 system first"
"When a problem is detected by self-diagnosis, the VSA control unit shifts to fail-safe mode"
As you said, it's fixed, so this is speculative and, at this point, academic...
