D2R Low Beam Headlamp Replacement - How?
Old Nov 26, 2004 | 06:04 PM
pkane's Avatar
Old Fella
Anyone know how to replace the low beam on an 01 CL-S? The manual warns that it should be done by a dealer as it is High freakin' voltage..... I can't believe that we can't do this ourselves.... I search the whole board and came up blank....
-Pete
Old Nov 26, 2004 | 06:44 PM
htown's Avatar
3-piece FTW
remove the headlights, use a t-20 torx socket w/ a wrench you can buy this at any autozone, oreillys etc..
Old Nov 26, 2004 | 08:17 PM
NiteQwill's Avatar
Adventurist.
The only high voltage system is the actual ballast of the lighting system, it delivers 35000 Volts in the initial spark. You can change the lights yourself, just don't turn anything on without everything connected first.
Old Nov 26, 2004 | 08:30 PM
AMorgCLS's Avatar
Girls luv me Guys hate me
Also as a precautionary measure, disconnect the battery just to be on the safe side.
Old Nov 27, 2004 | 10:19 PM
pkane's Avatar
Old Fella
Have you seen the warning sticker that is on the access point to the bulb itlsef? It says that it contains high voltage and can result in a fatality. How do you discharge the stored voltage before opening the thing up? The high beam bulb is a piece of cake as I understand it. It's the low beam one that has all the voltage....
Thanks for all the help!
Old Nov 28, 2004 | 12:25 AM
2ND_TIME_CLS's Avatar
I'm Back One MO' Gin
when I changed mine I didn't know about that tool til it was too late to go find one,So I used a small flat head screw driver and It worked like a charm.
Old Nov 28, 2004 | 12:30 AM
pkane's Avatar
Old Fella
And you're obviously alive to talk about it as you didn't get zapped by 25,000 volts! Nicely done!
Old Nov 28, 2004 | 03:08 AM
greyjhu's Avatar
DC Cruiser
there is a disconnect for the D2R bulb wire leads from the ballast. Once the leads are disconnected, it's safe to handle the headlight unit. The ballast can hold a charge, so once it is diconnected you should be fine. a screwdriver was used to remove the bolt initially, and afterwords I never replaced it since the back of the housing screws on and sits tight.
Old Nov 28, 2004 | 03:22 AM
NiteQwill's Avatar
Adventurist.
I deal with lighting, I have assembled several HID units for several makes and models of cars.
The damn bulb has no "STORED" voltage.... That's impossible, it can't store energy then release it, it would need a special chemical substance to do that
The BALLAST creates the high voltage Only when you turn your car on does the ballast turn on. So just disconnect the battery then, and you're safe.
Disconnect the bulb, insert new bulb, reconnect, and viola! You're all set to go.
Old Nov 28, 2004 | 09:47 AM
pkane's Avatar
Old Fella
Id
Thanks NiteQwill! That's the answer I was looking for!
Course, if you don't hear from me again, you'll know I'm laying on the garage floor, zapped....
Old Nov 28, 2004 | 10:23 AM
kevin79925's Avatar
How many ACLers does it take to change out a light bulb?
Old Nov 28, 2004 | 12:32 PM
rbf351's Avatar
Registered User
looks like way to many
guess i should be dead since i install a set on my old civic and also turned them on while they weren't in the car
and the warning sticker
Old Nov 28, 2004 | 10:58 PM
Chopsie's Avatar
Beware of leakage
In all reality It could take all 16k of us (formally A-CL) from everything from quote upon quote, to IBTHESHOCK responses.
Feb 25, 2020 09:57 AM
TLDude876
Dec 28, 2016 03:18 PM
Glorygang600
Sep 5, 2015 01:17 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
