Creaks And Squeeks!!!???
Changin bulbs since '73
A 30K car and it the back seat creaks. Can this be right? Does anyone else have this problem? My Jeep Wrangler (!) didnt have this problem!!! Don;t get me wrong i love this car but didnt expect these kinds of problems from an Acura. The "mystery noises are killing me!!!
I had the same problem. This awful creak coming from what seemed like the back seat. I got someone to drive and sat in the back. I could not find where it was coming from. It almost sounded like it was the rear window creaking. Anyway after furthur investigation I pulled down the overhead lining a little and discovered that it is this little piece of metal with white plastic things clipped into it stuck onto the window with sticky pad. If I pushed on the metal it would stop creaking. When I got home a I sprayed some wd-40 on the sticky pad and also put vaseline around it, then pushed the metal piece up hard with a screwdriver. Since then it hasn't creaked again. This is on the drivers side in the back.
Now I just have to get my windshield that leaks water fixed!
Stealthy A-CL Member
This is where mine rattles & squeaks. You might want to check these spots too. Oh, and I think the FAQ mentions some other areas to check.
The rear defroster connector cover on the rear glass was loose.
The BOSE badge on speaker grill was loose and would rattle with bass.
Vasaline? And what? Dammmmmmn!!!! I have to do that on a brand new car? HAhahahah!! Oh well, what are you gonna do! Thanks for the help.:P Are there other things i should know about? I get a new noise everyday that seems to disappear when the next one appears!!
