could someone explain this, i just got it while trying to get on the site
teh Senior Instigator
WinProxy has detected an error while verifying the name for the following request:
HTTP://www.acura-cl.com/
When the name for www.acura-cl.com was requested, acura-cl.com was returned with an IP address of 209.113.46.91.
Performing reverse name verification on 209.113.46.91 returned 209-113-46-91.kticorp.com.
This error could be due to an improperly configured web server, or an attempt to redirect your request to a different server.
If you would like to proceed with the new name follow this link:
HTTP://209-113-46-91.kticorp.com/
If you would like to proceed without reverse name lookup verification, follow this link:
It is very likely that this is simply a misconfigured web server, and one of the links above will solve the problem. Although it is rare, it is possible that someone is attempting to "spoof" the name of the original server. If you are not sure if the new domain can be trusted, then you should follow the links below to get information on the requested names: (This will only be available for .COM domains)
Search InterNIC database for acura-cl.com
Search InterNIC database for kticorp.com
"the needle got buried at 140.....1,500 RPM later...the tach got buried"
