Coolant Smell
Coolant Smell
Hey guys,
Recently I have been noticing a coolant smell after driving my car (01 CLS). Last night I changed the oil and did not notice any coolant leaks. I rarely use the AC. The car has ~75k on it.
Should I take it into the dealer?
Originally Posted by Moodist
It could be a very small leak that you don't notice. Do you see any liquids under the car after it has been parked all night?
Originally Posted by g1underground
Check your heater core under your dash. If they go bad you can smell coolant.
I don't smell it inside the car unless the windows are open. I took a peek under the hood with a buddy and he noticed some dried green substance below the thermostat housing. I spoke with a tech at my local Acura dealer and he said it could be a loose hose, cracked housing or bad gasket. He also said there is pretty much no way it's the head gasket. They'll check it out Saturday.
cycdaniel
12-17-2019 10:58 AM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
